29th Mar 2012, 1:32 am | #1 |
Restoring my Philips Magnetband Schreiber.
I am working on my Philips Magnetband Schreiber machines.
Problem is I can't manage to get the reel tables off. Anyone out there have a Turnbuckle style machines and removDe the tables from it? Thank you, Chris |
29th Mar 2012, 8:54 pm | #2 |
Re: Restoring my philips magnetband schreiber
Hi Chris,
It depends on how they are put together. On my HTS for example, the two tape locks have a large screw (around 1cm large on the top part) attaching them to the tables. They are "severely" screwed by design: the end of the axis has two cuts forming a +. Thus, the end of the axis has four parts which can be spread against the table hole to lock it. The screw starts with a constant thread diameter (like 3mm) and finishes with a conical shape which, as far as you screw, will spread the four parts of the axis against the hole of the tables, thus locking them. On my HTS I really had to lock the motor using a screw driver toward the bottom fly wheel in order to unscrew using the appropriate screw driver. Don't think about using anything smaller than the screw, you really need full "force" to unscrew. I think this design was used on almost every AEG Magnetophon model. |
29th Mar 2012, 11:35 pm | #3 |
Hi David,
I figured them out last night after my post. My tables are held on exactly the same way your magnetophon HTS holds its tables. The picture is my current progress on it. -Chris |
30th Mar 2012, 8:16 am | #4 |
Beware of the material used on that bedplate. If it's zamac, it will definitely break soon or later somewhere else. This material, when not properly made, does not age well and becomes too brittle against weight. You should dismantle everyting to separate the bedplate itself, and ask a professional to mould one for you, and use the shape of the other hole to remake the broken one. Quite some work, but the only reliable solution in my opinion.
30th Mar 2012, 7:18 pm | #5 |
I'm using aluminum weld and building it up. It's the strongest type for casting, it's from a company called Devcon.
It's for cast aluminum which is what mine are made of. Chris |
1st Apr 2012, 2:39 am | #6 |
Re: Restoring my Philips Magnetband Schreiber.
Now the hard part comes, one of the motors has a bent shaft and the table moves up and down as it rotates.
Does anyone know how to rebuild the motor and unbend the shaft without snapping and denting it? -Chris |
6th Apr 2012, 12:44 am | #7 |
I need some serious help with this, the shaft is nearly straight, but I need someone who could help me get it exactly straight.
Is there a service out there to do this? -Chris |
27th Apr 2012, 6:02 am | #8 |
Now, I have this transport finished but need to run a test on it, I would like to power it up via my variac. Is it safe to do this with the motors? I think the caps should be reformed, there is a rather large bank of them.
-Chris |
27th Apr 2012, 12:47 pm | #9 |
Should be ok via a variac, just be ready to yank the plug if any smoke or noise comes.
Regards, Ben. |
28th Apr 2012, 1:40 am | #10 |
So using 75 watt current limiter, then variac, then 120volt to 220 volt step up transformer (provides isolation too) all plugged into a RCD(GFI)
-Chris |
28th Apr 2012, 2:44 am | #11 |
With 75 watts I can only get 40 volts out of my variac, the load is so much the bulb is glowing full on.
-Chris |
28th Apr 2012, 8:01 am | #12 |
The limiter needs to be in the secondary circuit of the step up transformer. The current there will be half that in the primary.
28th Apr 2012, 12:07 pm | #13 |
The limiter will need to be 220V, or you could use two 110V types in series.
28th Apr 2012, 7:20 pm | #14 |
The machine runs, i wasn't using the limiter with the machine, i was limiting with 500 watts the amount of power going to the variac, and it worked quite well in that setup.
-Chris |
28th Apr 2012, 7:24 pm | #15 |
So you've changed the limiter from 75W to 500W?
28th Apr 2012, 7:44 pm | #16 |
75 to 150, to 500 watts.
-Chris |
29th Apr 2012, 2:45 am | #17 |
Now, for powering up the Preamps, i have inspected them for any loose connections and mended the faults.
How should i power these up, via variac with 75 watt limit again? With 75 watts i can achieve 35 volts, 150 watts around 55 volts, and 500 watts around 100 volts, so should i power them up that way, without the valves in place first? Or should i not take the risk and put the valves in. What of the tape heads, don't they have to be plugged in so it doesn't damage the amplifier? (don't valve amps need the load?) -Chris |
29th Apr 2012, 10:22 am | #18 |
I'm not familiar with the circuit for these devices, but generally, unless the rectifier is plugged in the smoothers won't get reformed. By all means progressively increase the wattage of the limiters.
I assume the voltages you're quoting are for the output of the variac which is the same point as the input to the step up transformer? It's the voltage at the output from the step up transformer that matters though. I still think the limiters should be in the 220V side. Their brightness or lack of it will then give you an idea as to what's going on.
