3rd Mar 2019, 5:10 pm | #1 |
Revox B710 only plays ½ a tape
After working on a B710 which had a partially seized RH capstan motor shaft, all works properly except that after about ½ of a 30-min tape the machine stops. I’m wondering if it could be a problem with pinch wheels.
Any ideas?
3rd Mar 2019, 8:24 pm | #2 |
Re: Revox B710 only plays ½ a tape
Is it maintaining true tape speed and then going to stop suddenly, or does tape speed first start to slow, wow etc? What was the initial symptom?
3rd Mar 2019, 10:20 pm | #3 |
Tape seems to play normally then just stops. The initial symptom was that the RH capstan didn't run at all because the bearing was stiff. If I adjust the pinch roller tension a little (maybe half a turn) it makes a difference to how far through the tape it gets.
I'll be trying some other tapes tomorrow to see if it's a faulty cassette.
7th Mar 2019, 5:55 pm | #4 |
It isn’t a faulty cassette.
7th Mar 2019, 8:13 pm | #5 |
It could of course be a faulty pinch roller.
