25th Feb 2019, 1:33 pm | #1 |
Akai 215D No reverse no autostop
As per the title ,
it seems that they are both dependant on being sorted to ground from what I can tell , the manual I have is awful though , so would the problems be related to each other ? The reverse / forward buttons do nothing , and the auto stop arm does nothing . Any ideas will be gratefully received . David |
25th Feb 2019, 1:43 pm | #2 |
Re: Akai 215D No reverse no autostop
Oh good grief, hahah, I guess this will explain it.
Haha. I'll replace all these and get back to you. That will explain the smell at least ..LOL. |
25th Feb 2019, 6:33 pm | #3 |
Had to order some 0.1`s ........to be continued .
25th Feb 2019, 8:15 pm | #4 |
Ooh, a box of fireworks and it's not even November!
Regards, Ken. BVWS member |
25th Feb 2019, 9:10 pm | #5 |
Those capacitors look ok to me and I doubt that that is causing your fault,
25th Feb 2019, 9:22 pm | #6 |
What on earth do they all DO?
I thought that model was a fairly ordinary 2-lever Akai mech with 7" spools. With hardly any need for a jumping cracker. David
25th Feb 2019, 9:24 pm | #7 |
Snubbers.
Lawrence. |
26th Feb 2019, 12:06 am | #8 | |
David , as Lawrence says they are snubbers , except they are separate resistors and caps. I must admit they took me by surprise when i flipped the board over , there are 3 burned out resistors amongst that lot too so they are going to need replacing ****** rifa caps are a pain . Last edited by NorfolkDaveUK; 26th Feb 2019 at 12:13 am. |
26th Feb 2019, 12:56 am | #9 |
Ok the AR is fixed the previous repairer attempt left out a "top hat" in the sensing pole making the machine permanently grounded to forward play . I`ve got a few of those so put one in and bobs your tea pot . Now plays in both directions . I`ll get the rest of the caps changed tomorrow along with those burned resistors and hopefully that`ll be all it needed . Sounds pretty pants at the min but once calibrated it should come together pretty well I think . nice little machine really , well , apart from the fire hazard in the roof of it ..haha
26th Feb 2019, 10:00 am | #10 |
So I`ve still got no auto stop which is a little strange . its sensing the lever is up , but not shutting it off when it drops . Little bit strange , mmm...the plot thickens
26th Feb 2019, 3:07 pm | #11 |
Sussed it , bent "actuator" spring . Doing what it should now , all recapped , cleaned , and ready for calibration . On to the next.
