Reply
Old 6th Nov 2025, 9:17 pm   #1
Magical
Default Background Hiss from Output Amp Vintage Car Radio
Hello all,
I'm after some help please? I have noticed this phenomenon on a number of vintage car radios I've worked on over the last few years. Generally Radiomobile from the '60s and early '70s, model types typically 970, 980, 1070, 1085 etc. These are 12v negative or positive earth radios.
I've noticed on some that there is a very noticeable hiss, which does not change with the volume control. It can be present on push-pull or single output power transistors. I've never been able to identify what it is. I'm extremely confident it's the output amp as on the Radiomobile 970 models I've been able to easily swap output amps over and the his has gone away.
Has anybody come across this and have you been able to resolve the issue?
Many thanks in advance,
Nick.
Magical is offline   Reply With Quote
Old 6th Nov 2025, 9:33 pm   #2
paulsherwin
paulsherwin's Avatar
Default Re: Background Hiss from Output Amp Vintage Car Radio
Old Ge driver transistors often become noisy.
paulsherwin is online now   Reply With Quote
Old 6th Nov 2025, 9:51 pm   #3
Magical
Thx Paul, I’ll give that a look.
Old 7th Nov 2025, 11:51 am   #4
Silicon
Another possibility is that the noise is coming through the power supply.
Perhaps some of the filter capacitors have gone open-circuit.
Silicon is offline   Reply With Quote
Old 7th Nov 2025, 4:18 pm   #5
Magical
Hi Silicon,
Thank you for your idea. I've now found the culprit!
Thank you Paul,
You were right. I traced it down to the first transistor in the output amp on this particular radio. It's a Motorola 828 and it's the first Mullard OC82DM, which is indeed a germanium transistor.
Much appreciative of your suggestion and Silicon, I'll bear that in mind when this next comes up.
Cheers,
Nick.
Reply
