Reply
Old 15th Jan 2026, 12:21 pm   #1
technotel
Default Grundig C6000 Radio/Cassette
Hi all
Any tips and/or ideas for a noisy sqeeling cassette motor. Its sealed and sounds like it needs oiling or the bearings are shot? Is it or would it be possible to drop it in a jar of something like clock oil or would that just make it worse? Or dropping it into a ultrasonic bath? Maybe someone can tell me how to get into the casing perhaps? I have bought another Grundig spairs or repair in the hope its motor is ok?. It uses same motor. Be nice though not to have to rob it if theres any hope for the existing motor.
Many thanks.
technotel is offline   Reply With Quote
Old 15th Jan 2026, 7:56 pm   #2
technorob20
Default Re: Grundig C6000 Radio/Cassette
Hi, Do not advise dropping cassette motor in clock oil or similar. That would most likely ruin commutator and brushes. Try a very small drop of sewing machine oil at each end of bearing shaft. Do not over oil! If it's a motor bearing problem the squeaking should stop.
technorob20 is offline   Reply With Quote
Old 17th Jan 2026, 12:28 pm   #3
technotel
Many thanks for the tip. I have tried oiling both ends of the shaft, still sqeaks sadly...sigh!!
Reply
Copyright ©2000 - 2026, vBulletin Solutions, Inc.
Copyright ©2002 - 2026, Paul Stenning.
