Reply
Old 25th Dec 2025, 8:56 pm   #1
Richardgr
Default Repurposing transformer from Tandberg
I am looking for a suitable project for a transformer from a Tandberg 64 tape recorder.
As can be seen from the portion of the schematic, the secondary provides the 250V for the motor as well as being rectified for the needs of the plethora of double triodes.
I have no idea what power a motor for a tape recorder consumes. Standard equipment is a Papst HSZ 32.50-4-440 250V or Engel ES5030/4S 250V. The power demand for the unit is 65W, and at least 40W would seems to be needed for heaters, with some inefficiencies due to rectified AC, so could the 260V secondary be able to supply 100mA?
Name:	Skärmbild 2025-12-25 214953.jpg
Richardgr is offline   Reply With Quote
Old 26th Dec 2025, 11:08 pm   #2
paulsherwin
paulsherwin's Avatar
Default Re: Repurposing transformer from Tandberg
Probably. You need to load it and measure the output voltage with various currents while monitoring the temperature. If it doesn't get hot and the voltage holds up then it's OK.
paulsherwin is online now   Reply With Quote
Old 28th Dec 2025, 8:56 am   #3
Ed_Dinning
Note that even if the transformer is good for your application you should expect, say 5% regulation on voltages between no load and full load.
Temperature rise is the best indicator
Ed
Ed_Dinning is offline   Reply With Quote
Reply
Copyright ©2000 - 2026, vBulletin Solutions, Inc.
Copyright ©2002 - 2026, Paul Stenning.
