Old 10th Nov 2005, 1:22 pm   #1
Hoveradio
Hoveradio's Avatar
Default HT Power Supply from 12v Battery?
Hi,has anyone on the forum ever built an ht power supply using a 12v lead acid battery.I am currently trying to design a psu that will give me 144v at around 15ma.This is to supply my Lissen Conway battery wireless.I already have a 2v 12.5A/H cyclon cell for the lt supply.
I had originally thought about using 15 pp3 batteries but I think that these would only give about ten hours use.Rather expensive way of doing it!
Any views or comments regarding this would be appreciated.
Best Regards John.
Hoveradio is offline
Old 10th Nov 2005, 1:33 pm   #2
newlite4
newlite4's Avatar
Default Re: HT Power Supply from 12v Battery?
John, there was an article in one of the BVWS bulletins about six years ago where a 12V lead acid battery was used to power up an eliminator. The designer made it to match a mid '20s set, using it as a plinth. I seem to remember that it used a switch-mode circuit.
Neil
newlite4 is offline
Old 10th Nov 2005, 1:46 pm   #3
Biggles
I have tried various designs for invertors and had difficulties with no-load regulation. High frequency designs are probably more efficient but can produce "hash" that interferes with medium/long wave reception. I have had good results by driving a mains transformers in reverse at about 100Hz. This does not seem to produce interference. This may not be the ideal way to do it though and I'm sure the other forum members will have some good ideas on this.
Biggles
Biggles is offline
Old 10th Nov 2005, 1:48 pm   #4
Ed_Dinning
Hi Gents, you will need some sort of inverter to do this, I believe there are some commercial units and designs out there, but the main problem is the interferencefrom the inverter itself causing unwanted noise on the receiver it is operating. This csn vary greatly between sets. try and get one that operates at a low frequency, or you could look for an old vibrator as used on car radios and make an inverter from that. They typically operated at 400Hz, but could still produce some hash on the sets they were powering.
HTH
Ed
Ed_Dinning is offline
Old 10th Nov 2005, 1:50 pm   #5
Hoveradio
Hoveradio's Avatar
Hi Neil,I am going to be using a simple oscillator circuit and a transformer to step the voltage up.I am going to have to order some fast recovery diodes for the bridge rec circuit as I dont think a standard bridge rec is up to the high frequency.I'm also planning on limiting the voltage using a 150v zener at the output.
Regards John
Old 10th Nov 2005, 7:04 pm   #6
mikelect
mikelect's Avatar
Hi there is a design for one of these PSU's in the December issue of Everyday & Practical Electronics I saw it in WH Smith this afternoon HTH
Mike
mikelect is offline
Old 13th Nov 2005, 1:55 pm   #7
Hoveradio
Hoveradio's Avatar
Hi Mike,I have just bought the Dec issue of epe and their design for an ht psu looks very interesting.It's good in that the oscillator runs at 53hz so no nasty rf noise will be generated.
Regards John.
