Reply
Old 20th Oct 2025, 1:13 pm   #1
Lexicon
New Member
Default Kenwood A 85 hifi wires
Hi
I need help how to connect system control wires in Kenwood A 85 model.
Ther are 2 plugs in each unit
Cd. Cassette Player. Tunder. Equaliser.amp
Which one connects to which?
Thanks
Lexicon is offline   Reply With Quote
Old 21st Oct 2025, 10:44 am   #2
Uncle Bulgaria
Uncle Bulgaria's Avatar
Default Re: Kenwood A 85 hifi wires
This picture appears to show them all daisy-chained together. If you haven't got the original plugs and wires, you might find it rather difficult unless the connectors are generic and you can make up your own.
Uncle Bulgaria is online now   Reply With Quote
Old 21st Oct 2025, 1:35 pm   #3
Radio Wrangler
Radio Wrangler's Avatar
They look to be a sort of stackable connector of a type I've not seen elsewhere.
Stackable would mean all get connected in parallel. software has to sort out addressing and protocol.
Could be derived from Philips' I2C bus. Sony and Philips have collaborated several times.
Old 21st Oct 2025, 7:29 pm   #4
paulsherwin
paulsherwin's Avatar
This is an early 90s stacking midi system. To clarify, are you talking about the control links that allow the units to communicate with each other, or are you talking about the RCA audio connections? The units should be usable in standalone mode with just the audio links.
paulsherwin is online now   Reply With Quote
Old 22nd Oct 2025, 5:07 am   #5
FrankB
Fisher used to make systems using the proprietary interconnect cables also.
That said, look for missing jumper wires between the pre-amp outputs and the amp inputs.
FrankB is offline   Reply With Quote
Old 22nd Oct 2025, 7:54 am   #6
Edward Huggins
If you're not sure about those proprietary interconnects, just use standard RCA Phono cables and connect all 3 sections up as if they were "separates".
Edward.
Edward Huggins is offline   Reply With Quote
Old 23rd Oct 2025, 8:29 am   #7
Nickthedentist
Nickthedentist's Avatar
Good advice Edward BUT does the tuner have its own mains power supply, or does it draw power from the amp via one of the proprietary ribbon cables?
Nickthedentist is offline   Reply With Quote
Old 23rd Oct 2025, 9:10 am   #8
paulsherwin
Yes, it looks as if the tuner needs a low voltage supply from somewhere. The other bits seem to have mains inputs.
Old 23rd Oct 2025, 10:08 am   #9
Welsh Anorak
Welsh Anorak's Avatar
That shouldn't be a problem as the low voltage supply is hard wired to the tuner unit with a plug on the end of the flying lead for connection to the amplifier.
Some Pioneer systems also did this to save having multiple power supplies.
The second wire is for the remote control to link the units and is not absolutely necessary. If needed, this can be obtained as a spare part.
As Edward suggests, perhaps all the OP needs is a few RCA cables. Perhars he could let us know exactly what's missing?
Glyn
Welsh Anorak is offline   Reply With Quote
Reply
Copyright ©2000 - 2026, vBulletin Solutions, Inc.
Copyright ©2002 - 2026, Paul Stenning.
