| Vintage Audio (record players, hi-fi etc) Amplifiers, speakers, gramophones and other audio equipment. |
#1 |
I have recently acquired the above amp, D.O.A as sold.
initial visual inspection revealed R317L (100ohm) cooked, its in the collector feed to 2sd2390y, shorted, so its pnp partner 2sb1560 also changed as o/c collector to emitter. Found O/C on one side of R510L, these are twin 0.27ohm 5watt in single package, can i substitute 2 of the correct value, just commoning up the legs as i dont seem to be able to find the replacements. Then looked at C310l (100mf @ 80vw) way out of spec. I was going to change the 3.8v zener, nearest value i can get is 3.9v, would be ok? As always your advice valued, TIA. |
#2 | ||
Andy.
#3 |
Andy
Thanks for your offering, i am unable to find the OEM twin resistor (0.27ohm 5watt) as fitted anywhere on any of the usual sites. Ok on the zeners, i didn't think that they would be a problem, i would change both left and right channels, they test out as diodes ok but i was doing a belt and braces job on the equipment, whilst it was apart. watch this space as they say. |
#4 |
1. Individual 0R27 resistors fine
2. Zeners are there to act as back-stop current limiters for the ouput darlingtons. I'd sugguest using 3V6 as that's what the schematic device coding suggests ? 3. C310 value is non-critical and anything from 10 to 100uF @ >10V fine. John
When you don't know what you are doing, do it neatly. |
#5 |
Ok John, the resistors arrived yesterday, so tomorrow i will fit them.
Ok on the zeners i was foolish! enough to buy a box with many values in, 3.6v are in there. Thanks for your input. I can always rely on sound, pun intended, from the members on this site. |
