Reply
Old 17th Oct 2025, 2:00 pm   #141
julie_m
Default Re: Fidelity HF35T (Transistor version).
A ceramic capacitor will be fine in the C4 position. There are circuits where ceramic capacitors are preferrable to polyfilm, but this isn't one of them.
Now, if C3 (50µF; 47 will be fine as a replacement, anything between 10 and 22µF will do for testing, just take care with the polarity) were faulty, that would cause a loss of gain, while all DC voltages appeared beyond reproach.
julie_m is offline   Reply With Quote
Old 17th Oct 2025, 2:17 pm   #142
Boulevardier
Originally Posted by HRichard View Post
Q4 is dead.
Could the OP tell us what is meant by "dead"? How did he measure C4, and what resistance readings (if any) did he get (see posts 132 and 134)?
Mike
Boulevardier is offline   Reply With Quote
Old 17th Oct 2025, 2:27 pm   #143
HRichard
Dead as in open circuit on the meter Mike.
I've dropped in an electrolytic as that was all I had of that value.
I have sound through the speaker but it is still very low volume, but at least progress.
HRichard is offline   Reply With Quote
Old 17th Oct 2025, 2:43 pm   #144
julie_m
A capacitor will read open-circuit on a resistance meter, unless it is faulty (and NB, not all capacitor faults will cause it to have a finite resistance, so open-circuit doesn't necessarily mean it's not faulty).
The C4 position should not need to be an electrolytic capacitor, as it will be a low value (100nF?). What value did you use?
Old 17th Oct 2025, 3:19 pm   #145
HRichard
It was 0.1uf but all I had until tomorrow.
I will also look at C3 but changing C4 has definitely made a step forward.
Old 17th Oct 2025, 3:59 pm   #146
julie_m
A 0.1µF capacitor is very unlikely to be electrolytic -- non-electrolytic capacitors are readily available up to at least 1µF. Can you post a picture of it, please?
Old 17th Oct 2025, 4:14 pm   #147
HRichard
A little fuzzy but I think you can make it out.
Old 17th Oct 2025, 4:58 pm   #148
julie_m
Well, it looks like 0.1µF -- and yet it looks like an electrolytic!
Très étrange, as they say in Paris! Every day's a school day .....
Old 17th Oct 2025, 5:03 pm   #149
Boulevardier
Has it got any markings to distinguish positive from negative leads?
Old 17th Oct 2025, 5:11 pm   #150
HRichard
Yes it does
Old 17th Oct 2025, 6:21 pm   #151
music-centre
Yes, surprising they make them in that small value. I saw these on the CPC website Today when ordering some parts though.
https://cpc.farnell.com/multicomp-pro/mcmhr50v104m4x7/capacitor-0-1uf-50v-radial-105/dp/CA08233
music-centre is offline   Reply With Quote
Old 17th Oct 2025, 7:08 pm   #152
HRichard
As a side question, it looks like someone in the past has soldered an extension to the headshell wiring. Is this acceptable?
Old 17th Oct 2025, 7:28 pm   #153
Boulevardier
Depends what it is. Can you post a very clear photo of this?
Old 17th Oct 2025, 7:31 pm   #154
HRichard
The joint is covered with heat shrink sleeve so wouldn't show anything.
I only know that wires have been joined because the wire colour used doesn't match.
Old 17th Oct 2025, 7:34 pm   #155
Boulevardier
Could be crucial. You'll need to cut off the heatshrink by slicing it along length with a sharp blade and then peeling away.
Old 17th Oct 2025, 7:50 pm   #156
HRichard
In what way crucial, Mike?
Old 17th Oct 2025, 8:25 pm   #157
Sideband
Sideband's Avatar
What is the original value of C4? You say you've used a 0.1uF (which seems a bit low) which is all you had.
Too low a value will likely cause low sound.
Sideband is offline   Reply With Quote
Old 17th Oct 2025, 8:49 pm   #158
HRichard
C4 (Mylar I think) is marked 0.1k 100
Old 18th Oct 2025, 7:21 am   #159
Station X
Station X's Avatar
The service sheet shows C4 as being 0.1uF. I think we've been round this loop a few times now.
Originally Posted by Station X View Post
If you're using the diagram attached to post #22, C4 is the capacitor connected to the wiper of the volume control. The service sheet for the HF35, where it's designated C3, gives a value of 0.1uF.
Graham. Forum Moderator
Station X is online now   Reply With Quote
Old 18th Oct 2025, 11:56 am   #160
Sideband
Sideband's Avatar
OK, it will be an ordinary capacitor...I wouldn't use an electrolytic here even if you do have such a thing at 0.1uF. There is no real polarising voltage available so just an ordinary Mylar or polystyrene type will be fine.
Reply
Copyright ©2000 - 2026, vBulletin Solutions, Inc.
Copyright ©2002 - 2026, Paul Stenning.
