#101 |
If you have 27V at the centre connection of those two resistors then there is a problem....it should be about half supply so you should be measuring about 13.5V. What does the collector of the bottom transistor (AC128) measure? I'm assuming you have your negative meter lead connected to the negative rail? There should be nothing on the collector (since it's connected to the negative rail), about 13.5 on the emitter and probably about 14V on the base (since you only need around 0.2V between emitter and base to turn on a germanium transistor).
Come back with your results.
#102 |
I'll check Q3 again tomorrow, but the other day was
Q3 - 22, 21, 0 I'll also recheck the resistors in case I am measuring in the wrong place. |
#103 |
Just to be sure, I was measuring at the top left where the 2 pads are joined?
#104 |
Simple as this amplifier is, I wonder if we've just hit the good old "DC-coupled amplifier" syndrome - going round in circles replacing components, only to find them failing again because by now so many are possibly implicated and none of the voltages make much sense. 104 posts so far, and not much further on. Perhaps it will be quicker to remove and test all the transistors again, and test all the Rs and Cs.
Quicker still just to rebuild the whole amplifier board with new components - there are few enough and they're all cheap enough. Mike Last edited by Boulevardier; 14th Oct 2025 at 9:47 pm. |
#105 | |
Anyway, I'll lok at it again later. |
#106 |
Checked and double checked (and realised that I am an idiot)!!
Junction of 2.2 ohm resistors = 13.35v AC128 e - 13.28v b - 13.22v c - 0v |
#107 |
If that's the case then looks like the output transistors are fine, as this is correct and if either were shorted would get 27 or 0
Is it possible C4 is open circuit or a problem with the volume control? Maybe the amplifier is fine now. maybe a signal of some kind could be inserted at the volume control? |
#108 | |
Have you tried the "Buzz test" again - slide off the wire connectors to the cartridge (just in case the cartidge is damaged and low resistance), and touch the now-free connecting leads with a screwdriver blade. Mike |
#109 |
Also, as Smiler suggested, try the same test again at the volume control.
#110 |
Re buzz test.
From the cartridge leads - nothing. From the volume control - nothing If I apply a small voltage directly to the board where the cartridge wires attach I get crackles. Measuring resistance across the volume control ranges from 370 to 368 ohns. |
#111 |
PS. Is C4 the big smoothing? cap?
#112 |
I'd expect around 1M with the cartridge disconnected.
#113 |
No, we're not talking about the smoothing capacitor.
If you're using the diagram attached to post #22, C4 is the capacitor connected to the wiper of the volume control. The service sheet for the HF35, where it's designated C3 gives a value of 0.1uF.
#114 |
Now at Post 113 and counting.......what circuit or version are we talking about here?
Edward. |
#115 | |
Don't know the value of the volume control but 370 ohms is very wrong!! I think someone said they would expect 1 megohm? That sounds right for a crystal cartridge. So...there is another thing to check. Make sure the control is connected correctly. If necessary, disconnect any leads connected to it and measure directly across the track (the two outer connections). Then check from the wiper (centre) to each outer connection while turning the control. Volume controls don't normally go short circuit but if it's been messed about with in the past, then nothing is impossible. Check the value of the control (usually marked on the side). If it measures OK when disconnected then you need to check the external connections.
#116 |
There are 4 tabs on the combined on/off volume control.
2 are connected to the motor winding and 2 are 240v mains. As can be seen in image. |
#117 |
There will be 3 more tags on the lower silver part that is the actual volume part, I guess at the back as they can’t be seen.
#118 |
Those 4 tags with the blue and brown wires are NOT for the volume control - they are for the mains switch. You'll get rather more than a tingle or a buzz if you touch them! The volume control (3 tags) will be underneath the potentiometer as shown in your photo, and will probaby be wired directly from the tags into the PCB - so awkward/impossible to access except from the tracks on the other side of the PCB.
Mike [EDIT - crossed with music-centre.] Last edited by Boulevardier; 15th Oct 2025 at 9:12 pm. |
#119 |
OK, understood,, thanks both.
#120 |
The volume control on these can be a problem, if the wiper is open circuit it could explain your no sound problem. Sometimes you can dismantle them to repair. If you just check the resistance between the middle connection on the control and either of the 2 other terminals it should change smoothly as you turn the control. If it is very high at all positions of the control (eg 1M+) this will be why you get no sound
