Reply
Old 6th Oct 2025, 12:55 pm   #81
Sideband
Sideband's Avatar
Default Re: Fidelity HF35
Originally Posted by HRichard View Post
Outputs - one is marked AC128 but the other has no markings so assuming AC126?
No AC126 is PNP and lower power. More likely AC127 which is NPN complement to AC128. I'm not at home at the moment so can't check the circuit. It could also be AC176
Sideband is offline   Reply With Quote
Old 6th Oct 2025, 6:37 pm   #82
Sideband
Sideband's Avatar
If you need a couple of transistors, as I said in post #74, I can let you have a couple for cost of postage. Actually the AC176 and AC128 is a very common pairing and the AC176 has a higher collector current rating than the AC127 so it's a better choice. You would be better changing the pair since the AC128 may have been stressed as well. Also check the two 2.2 ohm emitter resistors. When the output stage is working correctly, you should be able to measure approximately half the supply rail at the junction of the two resistors.
I thought I had a circuit for the HF35 but its the HF25.....
Old 6th Oct 2025, 6:42 pm   #83
HRichard
Many thanks sideband.
I will message you now.
HRichard is offline   Reply With Quote
Old 13th Oct 2025, 12:17 pm   #84
HRichard
The kindly donated transistors have made no difference at all.
What next
Old 13th Oct 2025, 12:46 pm   #85
Sideband
Sideband's Avatar
Take some voltages around the output transistors. What is the mid-point voltage?
Old 13th Oct 2025, 1:46 pm   #86
HRichard
Apologies again for my lack of knowledge, but how do I measure midpoint voltage exactly?
(I did use the search function but couldn't find a how to explanation).
Old 13th Oct 2025, 3:48 pm   #87
Boulevardier
Meter set to DC Volts; black probe on negative lead of C7 (500 microF) and red probe on junction of R9 and R10 (both 2.2 ohms).
Another point, there are 3 electrolytic capacitors in this circuit, and unless they've already been replaced they are ca. 50 years old - even if they haven't failed yet, they probably will eventually. Sensible to just replace them as a precaution (those meters [post#72) can give strange results with electrolytics, and you can destroy the meter if they aren't thoroughly discharged, so safer and more thorough just to replace).
Mike
Boulevardier is offline   Reply With Quote
Old 13th Oct 2025, 5:25 pm   #88
HRichard
Hi Mike,
can I ask to which circuit are you referring please?
Old 13th Oct 2025, 5:45 pm   #89
Boulevardier
I was looking at this schematic. Have I got the right one?
Doc6.docx
Old 13th Oct 2025, 6:26 pm   #90
Keith956
Keith956's Avatar
That schematic has an error in it - the junction of R2 and R3 should be connected to the base of TR1, else it will be floating!
Keith
www.peardrop.co.uk
Keith956 is offline   Reply With Quote
Old 13th Oct 2025, 6:29 pm   #91
Boulevardier
Yes agreed - if it wasn't connected to there there'd be no point in having two separate resistors!
Old 13th Oct 2025, 6:30 pm   #92
Station X
Station X's Avatar
The circuit was reverse engineered back in post #22.
SPICE details in post #78.
Graham. Forum Moderator
Station X is online now   Reply With Quote
Old 13th Oct 2025, 6:56 pm   #93
HRichard
Unfortunately I don't understand or have any knowledge of SPICE and for just a simple amplifier circuit where everything appears to test OK is just frustrating me immensely. I'm starting to think the fault is somewhere before the amp....
Old 13th Oct 2025, 7:18 pm   #94
Edward Huggins
The only thing before the amp is the cartridge and we've been there already. After 93 Posts on one of the most simple amplifiers in the World, maybe it's time to get a second opinion, hands-on, from a local Member near to you?
Edward.
Edward Huggins is offline   Reply With Quote
Old 13th Oct 2025, 7:22 pm   #95
Boulevardier
I can't remember whether this has been mentioned earlier in the thread, but did the OP take a soldering iron to the connector pins on the new cartridge, or solder the leads to the slide-connectors while they were still on the cartridge pins (which makes it easier to fix them while soldering to them)?
Just a thought...
Mike
Old 13th Oct 2025, 7:27 pm   #96
Sideband
Sideband's Avatar
Irresepective of which circuit, please measure the voltage at the junction of the two 2.2 ohm resistors. These should be easily identifiable.
Old 13th Oct 2025, 8:02 pm   #97
HRichard
Just a thought...
Mike
Nothing soldered on or near the cartridge.
Old 13th Oct 2025, 8:03 pm   #98
HRichard
Happy to do that if anyone is around the Coventry / Leicester area?
Old 13th Oct 2025, 8:04 pm   #99
HRichard
Will do tomorrow.
Old 14th Oct 2025, 1:25 pm   #100
HRichard
Will do tomorrow.
I have 27v
Reply
Copyright ©2000 - 2026, vBulletin Solutions, Inc.
Copyright ©2002 - 2026, Paul Stenning.
