Reply
Old 23rd Sep 2025, 2:11 pm   #21
smiler411
smiler411's Avatar
Default Re: Fidelity HF35
maybe the driver transistor is shorted or you have an open resistor feeding it from the power rail, looks like there is no bias current for the transistors. That will be the small plastic one in the picture I think. I think points 3 and 4 that you measured should be around half the supply
smiler411 is offline   Reply With Quote
Old 23rd Sep 2025, 6:10 pm   #22
Marconi_MPT4
Marconi_MPT4's Avatar
Fidelity circuit is mostly similar to one published by Mullard in Transistor Audio And Radio Circuits (2nd Ed.)
I managed to reverse engineer the PCB from pictures posted earlier in the thread as it was fairly simple circuit, but might help with diagnosing the problem. I did briefly check it out to see if the amplifier worked.
Attached circuit....
What is the measured voltage on junction of R9(120k) / R7(330k)
Rich
Name:	HF35 Reverse Engineered.jpg
To an optimist a glass is half full; a pessimist half empty; an engineer twice as big as need be!
Marconi_MPT4 is offline   Reply With Quote
Old 23rd Sep 2025, 7:51 pm   #23
HRichard
Rich
Circa 17v
HRichard is offline   Reply With Quote
Old 23rd Sep 2025, 11:14 pm   #24
EmleyTim
EmleyTim's Avatar
Maybe I’m missing something but the circuit diagram is available from Paul for both this version of the HF35 (albeit with a T suffix to denote transistor rather than the earlier valve version, I imagine) ref A18411 and the later IC version ref A18412.
A18411 is only 2 pages - component values and circuit diagram, respectively.
I’ve repaired a couple in the past with no output and in both instances, it was a tin whiskers problem, hence my suggestion in post #10.
It could of course be something entirely different but, having established that the supply was ok at 27V, I’d check the output transistors next by the method of removing the common heat sink and briefly testing again. Not particularly scientific but it’s an easy check.
Regards, Tim
EmleyTim is offline   Reply With Quote
Old 23rd Sep 2025, 11:28 pm   #25
Marconi_MPT4
17V is slightly lower than expected but not enough to cause this fault.
What is the voltage across R6(2.2k)? Should be about 0.6V to 0.7V.
If within these limits it strongly points to the driver transistor (Q4) could be at fault, as suggested in post #21.
Rich
Old 24th Sep 2025, 8:17 am   #26
julie_m
@Marconi_MPT4, thanks for reverse-engineering that circuit more quickly than I could!
julie_m is offline   Reply With Quote
Old 24th Sep 2025, 9:14 am   #27
HRichard
Regards, Tim
Exactly the same readings.
Old 24th Sep 2025, 9:19 am   #28
HRichard
Rich
Measuring 4v
Old 24th Sep 2025, 11:57 am   #29
smiler411
smiler411's Avatar
If you have 4V across R6 then either R6 is open circuit or Q4 is faulty I would have thought
Old 24th Sep 2025, 2:32 pm   #30
smiler411
smiler411's Avatar
Q4 will probably be the small black plastic transistor towards the outside of the PCB. I would think any PNP type would do like BC558 or similar, wouldn't think its anything special
Old 24th Sep 2025, 2:34 pm   #31
HRichard
I've removed R6 and measured it to be in spec so I will try checking / replacing Q4 next.
Old 24th Sep 2025, 3:05 pm   #32
HRichard
Q4 is dead.
It looks like an ME040x ?
Other than a BC558 (which I don't have) any other suggestions for a suitable replacement?
Old 24th Sep 2025, 3:26 pm   #33
Keith956
Keith956's Avatar
2N2906? Any general purpose small signal silicon PNP should work.
Keith
www.peardrop.co.uk
Keith956 is offline   Reply With Quote
Old 24th Sep 2025, 3:39 pm   #34
HRichard
I've gone through everything I have and there's nothing suitable (all NPN) so I'm going to need to order some anyway.
Old 28th Sep 2025, 1:57 pm   #35
HRichard
OK, so we have progress.
Replaced the ME0404 with a BC508B.
The amp is now working in so much as there is sound from the speaker and a hum when switched on, but, there is no volume.
I can hear sound with my ear against the speaker but nothing from 2 feet away.
Volume control is on full, tone control doesn't change anything, sound is slightly muffled.
Please help, again
Old 28th Sep 2025, 2:20 pm   #36
Station X
Station X's Avatar
Buzz test?
Voltage readings?
Graham. Forum Moderator
Station X is offline   Reply With Quote
Old 28th Sep 2025, 2:56 pm   #37
HRichard
If I touch the red wire the hum gets louder, but no loud buzz.
Green wire, no noise at all.
Voltages on Q1 are circa 25, 13, 13v however Q3 gives 0, 13, 13v
Old 28th Sep 2025, 3:33 pm   #38
Sideband
Sideband's Avatar
ME0404 is PNP silicon, BC508 is NPN silicon (according to on-line data sheet)!! Wrong replacement! You need to change it for a suitable PNP like a BC558. With the correct transistor, check the lead outs as they may be different from the original (for example a lot of transistors have collector in the centre, BC558 has base in the centre) check the data sheets.
Sideband is offline   Reply With Quote
Old 28th Sep 2025, 3:58 pm   #39
HRichard
Sorry, that was a typo. It is a BC558.
I couldn't find a pinout for the ME0404 though.
Old 28th Sep 2025, 4:35 pm   #40
HRichard
Finally found the correct datasheet for the ME0404 and I may have fitted the BC558 upside down
Will report back later after I've eaten.
Reply
Copyright ©2000 - 2026, vBulletin Solutions, Inc.
Copyright ©2002 - 2026, Paul Stenning.
