Old 23rd Oct 2025, 4:59 pm   #1
cynfelyn
Default Dulci "Speaker" Units - What are they?
Hey all.
I'm new here and hope you are all well!
I've just inherited a couple of Dulci units that I believe are some sort of "speakers". Pictures are attached.
I searched online for "Dulci: and found this forum post (https://www.vintage-radio.net/forum/showthread.php?p=1594050), yet still couldn't work out the possible original use-case for them.
Does anybody know what they might have been used for, and if it's worth restoring them at all?
Any information would be very welcome!
Thank you.
Cyn.
ID:	320564   Click image for larger version
ID:	320565   Click image for larger version
ID:	320566   Click image for larger version
ID:	320567   Click image for larger version
cynfelyn is offline   Reply With Quote
Old 23rd Oct 2025, 5:25 pm   #2
guest
Default Re: Dulci "Speaker" Units - What are they?
Interesting. It looks like a little amplifier in one cabinet with a tweeter, with the other containing the 'bass' speaker. What I fail to spot, is the input to the blue unit.
Old 23rd Oct 2025, 5:29 pm   #3
TonyDuell
Could they be a 'baby monitor' one-way intercom? The light grey unit goes near the baby's cot, it contains a microphone (the Acos transducer) and a 2-valve amplifier. Wired to the dark-coloured unit which is a speaker and volume control, placed near the parents.
TonyDuell is online now   Reply With Quote
Old 23rd Oct 2025, 5:31 pm   #4
guest
You might have a point there, since ACOS made mics. and that would explain the absence of an input!
Old 23rd Oct 2025, 6:15 pm   #5
Beesmart
No l did not get my eBay purchase Dulci running, as noted here, they are most probably Baby Monitors from the sixties. So they would receive a signal and send it to a receiver in another location, or vice versa. My project is now early valve hi-fi.
I Think Tony Duell has the answer above.
Beesmart is offline   Reply With Quote
Old 23rd Oct 2025, 8:29 pm   #6
julie_m
What are the valves?
It might be worth taking some resistance measurements from each of the mains plug pins (Live, Neutral and Earth) to the metal chassis and each of the screw terminals to which the interconnecting plug connects. Just because there's a transformer, doesn't mean a set is isolated. I suppose the audio interconnection is on the secondary side of the loudspeaker transformer, at least .....
julie_m is offline   Reply With Quote
Old 28th Oct 2025, 6:54 pm   #7
cynfelyn
Thanks all! Really appreciate the input. Do you think anyone would want to buy them if I put them up for sale?
I really like the housing and would happily have kept them if they were normal loudspeakers!
Copyright ©2000 - 2026, vBulletin Solutions, Inc.
Copyright ©2002 - 2026, Paul Stenning.
