5th May 2010, 5:20 pm | #281 |
Re: Pye v4
That 84.5 Ohm if correct indicates that probably another resistor will have overheated severely as the feed resistors are higher than that. It might be worth simply looking for burnt ones.
5th May 2010, 5:25 pm | #282 |
Re: Pye v4
That's not a feed through capacitor is it Chris?
Dave |
5th May 2010, 5:28 pm | #283 |
Re: Pye v4
I think I've found C75 on your picture:
what does anyone else think? |
5th May 2010, 5:30 pm | #284 |
Re: Pye v4
I make it under the diode here:-
5th May 2010, 5:34 pm | #285 |
Re: Pye v4
ah, yes it could be, the one I've circled is looking more like C76 8.2pf.
5th May 2010, 5:36 pm | #286 |
Re: Pye v4
I would agree with Boom.
Measure resistance from the tag with the 6K8 to chassis to test C75. |
5th May 2010, 5:39 pm | #287 |
Re: Pye v4
That's interesting though Lloyd. I make your one C73 a .003 decoupler as well so Chris is looking for an identical one under the diode.
Sorry, totally messed that up. The round disc one connected to pin 8 is C73 so one of those is what Chris is looking for (under the diode). Last edited by Boom; 5th May 2010 at 5:44 pm. Reason: Put right |
5th May 2010, 5:48 pm | #288 |
Re: Pye v4
Tag with 6.8K resistance reads oddly, 0.386R
5th May 2010, 5:49 pm | #289 |
Re: Pye v4
5th May 2010, 5:50 pm | #290 |
Re: Pye v4
Well, we have found the problem then. The solution is going to be another story! You will have to try to snip the capacitor off the tag.
It's under the C76 8.2pF and has a wire running to the tag with the 6K8. |
5th May 2010, 5:52 pm | #291 |
Re: Pye v4
C75 is supposed to be a 0.003 everywhere else they've been hunts. Maybe due to the RF side they used something else. I will be interested to see what Trevor has in his.
5th May 2010, 5:53 pm | #292 |
Re: Pye v4
I can see it and it was hiding under as you say and it's the round flat disc jobby.
Excuse while I do a Homer Simpson run over the Durham Dales screaming. |
5th May 2010, 6:00 pm | #293 |
Re: Pye v4
It is difficult to tell from the picture - there is something under there?
I use a very fine pair of medical tweezers for this sort of work. You may need to remove the other connections from the tag to get at it but be careful as the coil has a wire to it. On the other hand you could just follow the homer approach and reach for the hammer. |
5th May 2010, 6:09 pm | #294 |
Re: Pye v4
Phew I'm back!
Ok I got it out, now I'm going to try and get a new one in. Working on those clocks over the years has finally served it purpose, lots of little bits to fiddle with I suppose on a positive note at least I know that the caps I cannot find are these types. Trevors is March 1953 this set is July 1953 we shall see if it's the same. PYE really could not have made this more difficult if they had tried Last edited by oldticktock; 5th May 2010 at 6:16 pm. |
5th May 2010, 6:12 pm | #295 |
Re: Pye v4
Does it measure s/c Chris? I thought these were pretty reliable.
Dave |
5th May 2010, 6:18 pm | #296 |
Re: Pye v4
0.39R I was under the same impression and was always intending to leave them well alone and with their difficult access.
I think I need a glass of your amber stuff Boom, for the next bit coming up. Hope you don't all think me stupid but can someone explain what was happening, why this caused the massive over heat on R131, I have to understand otherwise it's just a swap, move on and I learn nothing for next time. Chris Last edited by oldticktock; 5th May 2010 at 6:27 pm. |
5th May 2010, 6:27 pm | #297 |
Re: Pye v4
You can have a drop of my amber stuff when we see a picture on it.
Dave |
5th May 2010, 6:52 pm | #298 |
Re: Pye v4
Oh and this was the latest on screen before entering into the R131 battle, which I forgot to post
5th May 2010, 6:54 pm | #299 |
Re: Pye v4
It would be a good idea to check the resistance at C18 again.
C75 was a short circuit to earth. There is HT voltage of 200V at C102. There is a current path from C102 -> R131 -> R94 -> C75 -> chassis. R131=131 ohms, R94=150 ohms, C74=0 ohms (a short circuit). The total resistance for the current path is 131+150+0=281 ohms. Ohms law says V=I*R. I=V/R, I=200/281=0.71A. Power is given by W=V*I. But V=I*R. So power dissipated in a resistor is W=I*R*I Power dissipated in the 311 ohm resistor=0.71*311*0.71=157W So the resistor gets VERY hot VERY quickly and pulls down the HT rail for a bit before it melts... |
5th May 2010, 7:17 pm | #300 |
Re: Pye v4
Thanks PJL thats what I was looking for.
Wiring in this replacement cap is difficult but not impossible. I can get the connection to the top of the 6.8K fine the original earth point is a no go. I will just end up melting everything or having to disturb too much and the coil worries me. I think I shall just pick the nearest earth point which will be easier and hopefully will not put the circuit out as I know these circuits are designed around optimum placement. However the guy who designed this was very creative in his component placement and i'm uncertain he had optimum in mind, I'm sure me moving one earth point should be ok. |
