Television Standards Converters, Modulators etc Standards converters, modulators anything else for providing signals to vintage televisions. |
#1 |
Hi.
I have four MC1374 IC's that were used in a Channel 1 405 line modulator some years ago. I need to build one up but have no info at all on it. Does anyone remember these and if perhaps a PCB was or is available with a circuit. Mods I'm not sure if this should be posted here or in the info wanted section, please move if necessary, thanks.
Cheers, Trevor. 2M0GZQ BVWS, GQRP KLARC. Member |
#2 |
One that I built a long time ago was in 405 Alive
Perhaps it was that one? Now Here https://www.bvws.org.uk/405alive/tech/modulator.html Cheers Mike T
Don't care if it was a bargain why's it in my kitchen ![]() Mike T BVWS member. www.cossor.co.uk |
#3 |
#4 |
#5 |
Thanks chaps.
The ETF one is it. I made a couple many years ago, someone here gave me a couple of boards, both went to other collectors. I've one to make up and try at a lower frequency for a project. All will be revealed in due course. I've all the bits but no board unfortunately.
#6 |
Hi Trevor, was this one used in the David Loser cct in Television?
Ed |
#7 |
The attachments show an early ETF modulator. The example I have here required considerable modification before it would work.
The MC1374 was designed for negative modulation systems, that being the case a separate sync tip clamp is used to so that the sync tips can reference to zero modulation. An emitter follower is introduced between the input amplifier and the input pin of the MC1374. Seems that the IC demands a low impedance drive. The carrier oscillators can be modified to crystal resonators. Modulator will work on channel B4 frequencies. Information about the MC1374. https://www.circuitspecialists.com/c...27/mc1374p.pdf DFWB Last edited by FERNSEH; 4th Dec 2020 at 12:40 pm. |
#8 |
I built the ETF modulator on a breadboard three years ago to use with a PC graphics card project. It works so well it's still in the state you see it here.
I have started to build a slightly more presentable one on perforated project board, I must get round to finishing it. Anyway, my point is the absence of a custom PCB shouldn't put anyone off. Mine is tuned to B2, the free-running oscillators are no problem, set and forget. I didn't bother with the output filter, I don't think David did either.
-- Graham. G3ZVT Last edited by rambo1152; 9th Dec 2020 at 12:10 am. |
