10th Oct 2010, 2:09 pm | #21 |
Re: Motor type - synchronous or not?
A synchronous motor without a wound field (which would usually need brushes) will "cog" when you turn it by hand unenergised due to the action of the permanent magnet rotor's flux. You can exploit this to determine the number of poles without dismantling the motor.
Connoisseur made a budget range of turntables using synchronous motors(s), the first being a 2 motor job (33/45) with very soft idler wheels to decouple the jerky drive from the motor and the second having a belt drive, one motor and a dual pulley. I think it was the BD1. With a heavy platter and compliant belt, it worked quite well. The actual motor was cheap and cheerful. Leon. |
10th Oct 2010, 3:07 pm | #22 | |
This seems to match the rotor's construction: I think, to avoid getting into an argument with another EMT enthusiast (now seemingly backed-up by an EMT specialist), I'll conclude that my specific EMT 927A is definitely not fitted with a synchronous motor. Now to devise a suitable PSU. Without the felt brake components, the turntable runs slightly fast. I don't feel particularly inclined to track down and re-instate the missing parts as it's somewhat crude and is apparently noisy. That'd be objectionable in a domestic environment - but then, this wasn't designed for domestic use. |
10th Oct 2010, 4:12 pm | #23 |
Hi Kat
A company I worked for used to have to control small 240V 3 phase motors as part of the automated test equipment. We used an off the shelf controller called an Altivar. This was a 240V single phase in 240V 3 phase out mdule with remote stop start. The interesting point here is that it also had a speed control with a wde range of adjustment which I assume varied the frequency while still maintaining the phase angles. Not sure if there is much ont tinternet but it may be worth a look. Al
I won't tell you how I discovered that. |
11th Oct 2010, 9:32 am | #24 |
How pure a sine wave do you need?
If you don't mind it being a bit "steppy" (and the inductance of those windings should smooth the steps out nicely anyway), you could do it all digitally using logic ICs. A Johnson counter with a multiple of 3 flip-flops would give you a multiple of six states, from which point on you can take advantage of spin symmetry to get your three phases. If you could derive a feedback signal from a steady LED reflected from the strobe dots, you could even build the whole thing into a PLL. (For an extra touch of the unusual, you could have the speed changer work by mechanically shifting the sensor up and down to pick up on a different row of dots.)
11th Oct 2010, 10:40 am | #25 |
An Altivar is merely the brand name of Telemechanique standard industrial inverters. They are most commonly three phase 400v input and whatever output voltage and frequency you programme it for, within certain limits. They are also available with 240v three phase input and, in smaller Kw sizes, for 240v single phase input. But you can only get the output volts that you put into it, so you cannot get 400v output with only 240v input.
You can usually alter the output frequency manually or by an analogue input, 0-10v or 4-20mA. The more up market versions have clever electronics and include things such as PID control of the output frequency. Gordon |
17th Oct 2010, 1:47 am | #26 | |
As I recall the original TD125 had a single-phase oscillator-amplifier (with germanium PNP output transistors) with a post-amplifier capacitor phase-shift to provide a two-phase drive to the motor. I had always assumed that the motor was two-phase, but there is no reason why it couldn’t have been three-phase, with the capacitor phase-shift set accordingly. The TD125 Mk II I think had a separate amplifier for each of two phases. So possibly EMT retained the original motor – if it was of the three-phase type – and substituted its own three-phase oscillator-amplifier. Cheers, |
21st Oct 2010, 9:28 pm | #27 | |||
Without knowing very much about them, I'd guess they rectify incoming mains to produce DC, then use PWM to drive the output pass devices. Turning MOSFETs hard on or hard off would make for good efficiency and small heatsinks. (They must use PWM, mustn't they? One I looked at was claiming almost full torque at 1.5 Hz - that'd be about 43 rpm from a 1450-ish rpm motor. I can't see a motor intended for 50 Hz operation being too happy with 1.5 Hz sine wave drive...) But I doubt the intended applications have a moving-coil magnetic pick-up about a foot away from the motor. If the outputs are PWM, there'll be a lot of harmonics; these could be radiated then picked up. Though it makes the motor PSU less efficient, I think I'd prefer to drive the motor with something resembling sine waves. OTOH, I'm still interested in these variable-speed drives. I've just bought an old 3-phase motor to play around with. One reason is I'd rather experiment with PSU circuits connected to something other than the EMT motor. The other reason is I'm thinking about getting a small lathe; the motor is likely to come in handy for that and a variable-speed drive would save mucking about with belts and pulleys. I think, for the reasons above, fairly clean. If I haven't got harmonics of 50 Hz (and/or some switching frequency) present in the supply or the motor windings, there's less chance of undesirable noises ending up superimposed on the music. Quote:
I think that should be good enough (and probably will produce a cleaner waveform than the mains tends to be these days anyway.) Quote:
The main platter needs to keep rotating at the correct speed when the upper platter is braked, so I'd need to pick up a tacho signal from that. There's a lot of space under the platter; I could attach a strobe disc under the platter and use a reflective IR sensor to produce a tacho signal. Part of the fun would be to devise ways of attaching the disc and sensor such that they could be removed later and not leave any trace, but I already have some ideas about that. Cheers, Kat |
22nd Oct 2010, 12:53 pm | #28 | |
27th Oct 2010, 12:54 pm | #29 |
A small note: a synhronous motor will run below its synchronous speed if heavily loaded. I've noted this in the Bang & Olufsen Beocord line of reel-to-reel recorders, which use Papst synchronous motors. That the motor is in fact synchronous can be determined if nothing else by putting a stroboscope sheet on the motor; when it is running, the stroboscope lines are absolutely still. However, in fast wind mode, especially at the end of the tape, the load is significant, and the motor speed drops. Nothing really surprising; after all, a synchronous motor must be able to run below its synchronous speed if nothing else just to get started!
/Ricard |
27th Oct 2010, 1:21 pm | #30 |
That's just it - pure synchronous motors tend not to self-start. (If the rotor is really low inertia, it may pick up enough speed during a half-cycle before the next half-cycle causes it to reverse. Microwave oven turntable motors are of this type and start in a random direction).
However, I can imagine a synchronous motor running at below synchronous speed if occasional heavy loads are put on and then almost imediately removed - the rotor may slip a cycle and re-synchronise (a bit like a phase-locked loop losing lock and regaining it, or a TV timebase losing lock and regaining. The motion would have seen a brief jerk, and the long-time average speed would have dropped fractionally. The type of motor you refer to almost certainly has a rotor which operates in induction mode to allow it to run up to speed. |
