27th Sep 2005, 2:03 pm | #1 |
Cotton-covered mains leads (thread contains links).
I guess these are loosely a component...
What are peoples' opinions on keeping the cotton-covered mains leads? I have recently bought a Smiths electric Alarm-clock, and it appears to have its original mains lead - cotton covered flex with black and red insulation. It looks in good external condition, and the insulation looked fine when I put a plug on to check it. My thought was I would give it a zap at 500v or 1000v on a megger and check its insulation. If it was OK I woul leave it. I've never really had to think about this with radios - I have always just replaced an old 2-core lead with a 3-core one to earth the chassis. My universal sets haven't reached the top of the pile yet! Sam
Can he lead a Normal life, Doctor? No, he will be ... an Engineer. |
27th Sep 2005, 2:29 pm | #2 |
Re: Cotton-covered mains leads
I'm no expert but given you can still buy it for irons and the like you could just replace with new? If the insulation is rubber it may bebreaking down even if it meggers ok - you'd need to flex every bit while you wound the handle...
27th Sep 2005, 2:42 pm | #3 |
Like Jeremy says, it is not so much the fabric, but the rubber that is the problem.
If you do not want to fit modern cable, this is may be useful: http://www.periodhouseshops.com/acat..._Cable_28.html You can indeed get fabric cable in such as B & Q, but it is too hefty for a clock, and the yellow spots look garish.
Mike. |
27th Sep 2005, 2:52 pm | #4 |
OK, thanks for the replies. I think I will just fit two-core black-coloured cable that I have here for radios. Won't look out of place, and I don't want to run the risk of the old one shorting out.
Sam
27th Sep 2005, 7:37 pm | #5 |
I have some new black and gold stuff you can get from my website www.vintage-radio-resources.com
2 sorts, one is 0.75mm which is good for radios and some 1.0mm for radiograms, if that helps. |
11th Dec 2013, 1:02 pm | #6 |
This ebay supplier might be of interest to those restoring vintage radio sets or other appliances.
Newly manufactured mains flex of vintage apearance. http://www.ebay.co.uk/itm/Coloured-t...#ht_1424wt_805 I have no connection with them. |
11th Dec 2013, 2:30 pm | #7 |
Re: Vintage style mains flex
I don't think that link works.
But this one seems to work and lists a lot of possible suppliers. - Jeremy
11th Dec 2013, 2:32 pm | #8 |
Link now corrected.
