Old 23rd Dec 2017, 8:09 am   #1
madlyhs
Default JVC HR-3320EK Playing issues
I just bought a vintage JVC HR-3320EK.
The FF and REW works fine however,i'm having issues making it play.
I press play button the tapes is moving then approx 3 seconds then it stops. I press play again then the same problem.
I can see the tapes moving freely and both tape reels move freely.
I did clean all the parts.
Any suggestions?
I think i need new belts as well?
TIA
madlyhs is offline
Old 23rd Dec 2017, 3:36 pm   #2
dj_fivos_sak
Default Re: JVC HR-3320EK Playing issues
Does the tape counter run when you are in play mode? These usually have a hall effect sensor that stops the machine if it's not turning.
Regards,
Fivos
dj_fivos_sak is offline
Old 23rd Dec 2017, 4:54 pm   #3
John123
Also, it might not be completing the loading cycle properly so a new loading belt (and new belts in general) would be highly recommended.
You can try a temporary fix by placing a normal rubber band over an existing belt to see if that changes anything.
Regards,
John
John123 is offline
Old 23rd Dec 2017, 10:16 pm   #4
winston_1
Not on those early piano key machines.
Most likely the take up is weak and some tape is spooling into the machine. Run it with the covers off to verify.
winston_1 is offline
Old 24th Dec 2017, 12:58 am   #5
jayceebee
jayceebee's Avatar
Try pressing pause immediately after play, if the machine still shuts down then the issue is not with the Hall sensor which is definitely fitted to these machines to detect loss of takeup. It's likely to be either the head drum is not running at near enough the correct speed or more commonly, the pulley below the drum which is driven by a belt has slipped down it's shaft slightly due to a loose grub screw.
The pulley has two small magnets attached which pass over a pickup head, the resulting pulses are used to generate the drum flip flop signal. If it's missing or low in amplitude the mechacon will shut down the machine after 3 seconds.
John.
jayceebee is offline
Old 24th Dec 2017, 4:28 am   #6
toshiba tony
toshiba tony's Avatar
As Jayceebee suggests the favourite is the drum flywheel sitting low. Common problem in the day. Or more obvious, the drum belt has come off.
toshiba tony is offline
Old 24th Dec 2017, 6:54 am   #7
madlyhs
Thank you all for your feedback...
The top is removed ,and I can see the tape counter running. The loading cycle is complete as the tape runs freely.
I agree I feel all belts must be replaced any idea from where I can get hold of new set?
Will try to put a rubber band and press Pause immediately after Play to eliminate the hall sensor. I will also make sure the the belt has not slipped down the shaft.
Great suggestions hopefully I can get it to work.
Thank guys you for your support.
Merry Xmas to all
Al
madlyhs is offline
Old 24th Dec 2017, 7:02 pm   #8
dj_fivos_sak
There is a belt kit from Australia:
http://www.telespares.com.au/index.p...ucts_id=317340
A shop here in Greece also sells the same kit. I bought one for my HR-3330 and it fitted perfectly. If everything in the machanism is running OK, then your problem is likely the system control board isn't detecting take-up reel/capstan/drum movement or the hall effect sensor has failed. These problems usually require a scope to troubleshoot them.
Merry Christmas!
Fivos
Old 25th Dec 2017, 1:08 am   #9
madlyhs
I found the problem it was as Jayceebee suggested the the drum flywheel was sitting low. I fixed that and it start to play fine.
Thanks Dj Fivos for the info i do need a belt kit as well .
Merry Xmas
Al
madlyhs is offline
Old 26th Dec 2017, 12:41 am   #10
jayceebee
jayceebee's Avatar
Good to see you've got it sorted. I hope you manage get to find a set of belts, they're getting scarce now. A forum member who lives near my location sourced his from New Zealand of all places.
John.
Old 26th Dec 2017, 2:10 pm   #11
madlyhs
Yes, thanks to DJ Fivos for pointing me to
I ordered two sets
madlyhs is offline
Old 26th Dec 2017, 9:44 pm   #12
dj_fivos_sak
Glad I could help. Keep these old beasts running.
Old 27th Dec 2017, 3:12 pm   #13
madlyhs
Thanks DJ Fivos I'm doing my best I have another beast that I'd like to get working. Sony SL-8080 I just need belts for it.
madlyhs is offline
