Old 22nd Dec 2013, 3:20 pm   #1
kevinski
Default Valves
Hi, I'm trying to get my head around valves and what the pins are and where they go to. Using the information from the Valve Museum website I can sort of understand some of the names etc but what I'm stumbling over is the letters and numbers that are inside brackets i.e.
PCL83 pin 1 = a(t).
I presume that a = anode but can't for the life of me work out what the (t) means. Any help or a pointer in the direction of a website would be much appreciated.
Kevin
kevinski is offline
Old 22nd Dec 2013, 3:23 pm   #2
paulsherwin
paulsherwin's Avatar
Default Re: Valves
The PCL83 contains two valves in one envelope, a triode and a pentode. a(t) is the triode anode, and a(p) is the pentode anode.
paulsherwin is offline
Old 22nd Dec 2013, 3:29 pm   #3
kevinski
Default Re: Valves
What about pin 6 which just has a and nothing in brackets. Is that the pentode anode or something different. I am working on a Black Box which also has an ECC82 valve which has nubers in brackets i.e. pin 1 = a(2). What would that mean?
Kevin
kevinski is offline
Old 22nd Dec 2013, 4:01 pm   #4
Restoration73
Restoration73's Avatar
Default Re: Valves
This site merits extensive examination, methinks
http://www.r-type.org/exhib/aai0081.htm
Restoration73 is offline
Old 22nd Dec 2013, 5:21 pm   #5
paulsherwin
Default Re: Valves
Kevin
Yes, in that example a(t) is the triode anode and a is the pentode anode. When a valve is a double triode the first triode will be marked a/g/k and the second a(2)/g(2)/k(2). There's some variation but it all makes sense if you think about it, especially if you refer to a diagram of the valve.
Old 22nd Dec 2013, 5:39 pm   #6
Bazz4CQJ
Bazz4CQJ's Avatar
Default Re: Valves
Before getting involved with the electrode connections, have you grasped the basics of the modern valve numbering system? By which I mean that for the ECC81, E tells you it has 6.3V heaters, C tells you it's a triode and CC a double triode, and the 81 tells you it's a B9A base. When you can use that info to figure out what the valve is, understanding the designation of the connections follows fairly easily.
Bazz4CQJ is offline
Old 22nd Dec 2013, 6:09 pm   #7
kevinski
Default Re: Valves
Thanks Bazz, I had no idea they meant anything. Is there a website or a list somewhere where these are listed?
Thanks Paul, you're quite right, once some kind soul like yourself points you in the right direction it does have a logic that makes sense.
Restoration73, checked out that site as mentioned in my first post but I couldn't find a suitable starting point that coincided with my lack of knowledge lol.
Kevin
kevinski is offline
Old 22nd Dec 2013, 6:21 pm   #8
paulsherwin
Default Re: Valves
http://en.wikipedia.org/wiki/Mullard...be_designation
Old 22nd Dec 2013, 7:01 pm   #9
kevinski
Default Re: Valves
Brilliant Paul, many thanks
Kevin
kevinski is offline
