30th Jul 2008, 11:20 am | #1 |
Yaesu FT290R RF Power Output Problem.
hi , i have a yaesu ft 290r radio and it has a power output problem , if you tap the shell the power output alters from 1w to around 5w ,and then keeps altering during modulation any ideas please would be helpful other to this the radio works fine
30th Jul 2008, 12:20 pm | #2 |
Re: Yaesu FT290R RF Power Output Problem.
Hi Rick and welcome to the forum.
I've moved this to a more appropriate section. You might try http://groups.yahoo.com/group/FoxTango/ which is the best source I know for Yaesu related help and information. You'll need to register but it's well worth it. Regards,
Brian |
31st Jul 2008, 12:27 am | #3 | |
31st Jul 2008, 7:28 am | #4 |
I would suggest buying a copy of Practical Wireless, and looking for Harry Leemings column - he repaired radios like this for years, and is happy to offer advice on how to fix faults on older radios such as the FT290.
Just re read your post - The 290 is only rated for 2.5w of output power from memory. what mode are you checking power output in? FM, or SSB? If it is SSB, then the power will change as modulation is applied. Are we into the M6 series of callsigns now? or was that a typo? 73 Sean M1ECY
31st Jul 2008, 5:03 pm | #5 |
No they have run out of M3's, it sounds to me that the rig might be on SSB perhaps?
31st Jul 2008, 11:12 pm | #6 |
Rick,
Is your FT290R a Mk 1 (removable case bottom, internal C-cell batteries) or a Mk 2 (detachable battery pack on rear)? Does the fault occur when running on batteries, or on a 13.8 volt power supply? If on batteries, check all the springy connections and make sure they are scrupulously clean. I had a similar intermittent fault on my 290 Mk 1 which I eventually traced to dirty contacts on the transmit/receive relay. With care, the top can be removed and the relay contacts cleaned with a little Servisol. It has worked perfectly ever since. You should also check the high/low power switch which may have dirty contacts. 73
Phil Optimist [n]: One who is not in possession of the full facts Last edited by Phil G4SPZ; 31st Jul 2008 at 11:13 pm. Reason: Typo corrected |
14th Aug 2008, 1:17 pm | #7 | |
14th Aug 2008, 5:55 pm | #8 |
Re: wanted 2metre amp for yaesu 290r
I see from the Wanted section that you're now looking for a linear amplifier for this rig.
You'd do far better to fix your 290R than add a linear amplifier to it. If the output from the 290R, and therefore the input to the linear, goes up and down, then so will the output from the linear. It sounds like your 290R has quite a simple fault such as a dry joint, dirty relay contacts or possibly a loose connection on the aerial socket. Best to try and fix that first. Is there not some one at a local amateur radio club who can help you?
Graham. Forum Moderator Reach for your meter before you reach for your soldering iron. Last edited by Station X; 15th Aug 2008 at 11:02 am. Reason: Post moved her from another thread. |
14th Aug 2008, 9:44 pm | #9 |
Hello Rick,
I don't use my 290 really, an occasional idle monitor of an empty calling channel perhaps - and yes, I know I could call CQ but life's too busy! The point I'm getting round to is that I read somewhere (PW?) that running without having the aerial rod in place, even if retracted, was known possibly to damage the 290's PA. Between that and the 25kHz channel spacing it may be time to look for another perhaps... Regards Ant G0AJA |
15th Aug 2008, 10:09 am | #10 |
Could i suggest a search on the internet for known 290 faults,that may help you 73s David GM8JET
15th Aug 2008, 11:11 am | #11 | |
There is nothing to be lost by trying to repair this rig before buying a new one. Rick. What is your objection to joining a yahoo group? You could get a lot of help there. You could try connecting the rig to a dummy load and gently poking components with a plastic knitting needle to try and locate any dry joints. A blanket resoldering round the output stage might help. Did you clean the relay contacts as suggested? Is the output constantly high with the rig in CW mode with the key down.
15th Aug 2008, 8:34 pm | #12 |
Hello all,
From http://www.w1ngl.us/radios/ft290r/ft290.htm with thanks, we have: "NO RF O/P : PA If it is not PA (the most likely cause) then check diode D24 in aerial switching, check for L2012 physically shorting to copper screen, and check driver Q2021 and R69." My point about the aerial rod was perhaps badly phrased - obviously one wouldn't transmit into an open circuit anyway, but this set apparently needs the aerial rod in place even if it's fully retracted and not in use, as it would be with an external aerial. Regards Ant |
15th Aug 2008, 9:14 pm | #13 |
Although this would indeed seem like a dry joint or similar simple fault, before we get too far I would remind you that Rick (M6RLT) is the holder of a Foundation class licence. Therefore he can only use ready built transceivers or kit built ones and should not really be going inside rigs and doing repairs. As one involved in Foundation training myself, I have just discussed this with our other tutors who agree this is the case.
I hope Rick gets the problem sorted out, but it might be worthwhile getting somebody from his local club or one of his course tutors to have a look at it for him. Dave G3YMC |
15th Aug 2008, 10:02 pm | #14 | |
15th Aug 2008, 10:13 pm | #15 |
Hello Dave,
I've not followed closely the ins and outs of the current licensing system so I bow to your greater knowledge. But whatever happened to "self-training"? Gone down the road of general political correctness perhaps! Regards Ant |
15th Aug 2008, 11:45 pm | #16 |
Administrator
This seems to be wandering away from the original subject towards discussions that are not welcome here, and has already been the subject of two post reports. It is now closed.
19th Aug 2008, 7:54 pm | #17 |
re yaesu 290r
to all that gave advice i thank you , i have sorted the problem , it was a dirty joint , so again many thnkx ,m6rlt rick
