7th Feb 2008, 9:31 am | #21 |
Re: Implosion screens
Talking of glass , in a couple of my sets , tv22 etc im sure it say Armoured glass etched onto it ! and as to glass floors ,they must be very thick and I would suspect maybe laminated .
The plastic sheeting used im will be strong enough as long as its not brittle |
7th Feb 2008, 9:38 am | #22 | |
When used for glazing this glass has to be used with a special sealant, as normal sealant will attack the plastic from the edges and progressively turn it brown.
7th Feb 2008, 2:29 pm | #23 |
If I were replacing a missing flat glass implosion screen then i would definately go for Laminated , not toughned. Ive not heard about it degrading , but i refuse to use anything except Putty when im doing glazing ...Some of us ..may rememeber early laminated vehicle windows that turned yellow and degraded inside the glass .but i think we are going OT
7th Feb 2008, 3:29 pm | #24 |
Glass implosion screens are impossible to break. I tried to make a replacement glass for a TV22 from a larger one. I scored the line with my trusty TC cutter, several taps on the line with successively larger hammers failed to break the glass. I gave up after several attempts with a club hammer at full force failed to split the panel.
Neil
7th Feb 2008, 4:46 pm | #25 |
They are not impossible to break - beleive me! Tap one near the edge with a sharp blade or pointed instrument, especially edge on but make sure you're wearing eye protectors - they don't half go pop.
You're lucky you didn't score right through the toughened layer or it would have gone bang. The skin is basically more "tight" than the inner glass and if the skin is broken on one side there is an unequal force on the other side causing it to tear itself apart, often violently. It didn't half give me a shock the first time I found this one out - especially as I was up a ladder trying to crowbar a window into a double decker bus! You can hit it all you like face on with a mallet but one tiny crack at the edge and bang. Back on topic, I notice in the TV24 the edges of the glass are protected from any debris due to it being oversized and the rubber surround - is this true in other sets? Dom |
7th Feb 2008, 6:37 pm | #26 |
what do you mean by oversized?
7th Feb 2008, 8:33 pm | #27 |
Sorry not very clear, by oversized I meant it is bigger than can be seen from the outside by a fair margin IIRC, the margin behind the wood on one side and the rubber mask on the other.
It also seems quite heavy for its size and thickness... |
7th Feb 2008, 8:41 pm | #28 |
On th tv22 i dont think its much bigger than an inch all round ,due to there being no space
