Sets, Parts and Service Information Wanted (private buyers only, no swaps) If you need help obtaining components, sets or equipment, post a message here. Private buyers only - no traders. No swaps. |
#1 |
I can't find any proper data on the web. Does anyone happen to have more information? I do have some data on the microphone (type 4175)
John |
#2 |
Hi John. I used to live in this world. What do you want to know about it? Could start a thread in test gear, if you want to discuss using it.
cheers Mark
"The best dBs, come in 3s" - Woody Brown |
#3 |
Mark:
I've just this minute received a scan of the user manual from B&K UK. So a big thankyou to them! I have used an earlier version of this back in the 70's when I think there was an analogue meter / display? I'm hoping to use it to measure loudspeaker response, so will need to investigate the analogue outputs, which appear to be miniature jacks (smaller than conventional phone jacks). Happy to start a Test gear thread. Thanks, John |
#4 |
There will be something called ‘ac out’ which will be the signal itself, and probably also a dc signal proportional to the reading in dB which you could use to drive a plotter. In the absence of a semi- or anechoic room, you could do worse than lying the speaker on its back outside and measuring a couple of meters up in the air. On a dry day! The quickest way would be to use a noise generator and take the ac out signal into an FFT analyser of some kind - even a soundcard and then sort it out in matlab. Does excel do fft yet?
#5 |
Mark: yes, awaiting fine weather for outdoor experiments. :>)
I do have an HP FFT analyser (3561A) which is invaluable. Now to try to source the jack-plugs! John |
#6 | |
![]() Quote:
Have you had a look at REW John - http://www.roomeqwizard.com/ you should be able to use the calibrated mic in your 2235. What are the jacks? DIN type? Andy.
#7 |
Andy: the output sockets appear to be 2.5mm, presumably single-pole.
John |
