Old 6th May 2019, 1:43 pm   #1
stuartd
Default Sparta Fuller Crystal Receiver- help!!!
Hi folks
Set appears complete but it has two stray wires (marked in red) which aren't connected. Should they be, and if so, to where?
Thanks
stuartd is offline
Old 6th May 2019, 1:46 pm   #2
Station X
Station X's Avatar
Default Re: Sparta Fuller Crystal Receiver- help!!!
A picture of the other side of the board would help.
Graham. Forum Moderator
Keep the soldering iron hot.
Station X is online now
Old 6th May 2019, 1:51 pm   #3
evingar
evingar's Avatar
Some detailed info on the set here, including a picture of the deck underside (part of the "slide show"). There seems to be some stuff missing on yours
https://physicsmuseum.uq.edu.au/sparta-crystal-radio
Chris
evingar is offline
Old 6th May 2019, 1:54 pm   #4
Station X
Station X's Avatar
The RadioSpares variable capacitor is obviously not original.
Old 6th May 2019, 2:01 pm   #5
stuartd
Sorry .... Here it is...
stuartd is offline
Old 6th May 2019, 2:11 pm   #6
Station X
Station X's Avatar
It's difficult to tell from your picture whether both coils are still present. The tuning arrangement (moving one coil relative to the other) has obviously been removed and replaced by the variable capacitor.
It looks like there are five connections to the coils, which would fit in with the original arrangement.
Old 6th May 2019, 2:21 pm   #7
stuartd
Thanks Graham - another view for you. I freely admit to being all at sea here
stuartd is offline
Old 6th May 2019, 2:32 pm   #8
ms660
ms660's Avatar
Could it be that the whole tuning capacitor has done a swivel and the two wires to its connection tags have ripped off?
Lawrence.
ms660 is offline
Old 6th May 2019, 2:41 pm   #9
stuartd
Everything seems pretty firmly locked down
stuartd is offline
Old 6th May 2019, 3:22 pm   #10
ms660
ms660's Avatar
Either there's another connection to the tuning capacitor that can't be seen in the photo's, or the capacitor was never connected in circuit, or the capacitor was connected in circuit by its connection tags and has, for whatever reason, (including the possibility given previously) become disconnected.
Lawrence.
ms660 is offline
Old 6th May 2019, 3:30 pm   #11
stuartd
Hard for me to work out what ought to be connected to where :-(
stuartd is offline
Old 6th May 2019, 6:10 pm   #12
Station X
Station X's Avatar
Given that this set has been modified it's difficult for me too, to know which wires go where. Given a bit more information I might be able suggest suitable wiring though.
Are both coils still present, perhaps the smaller diameter coil is now under the larger one, and how many wires are brought out from each coil?
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Copyright ©2002 - 2020, Paul Stenning.
