Old 21st May 2019, 7:10 pm   #1
geeoboeh2s
Default An interesting thermionic device.
There are only two contacts, a 1mm lead and a normal valve top cap.
There is no longer a vacuum in the glass envelop with the 1mm lead. The other envelop with the top cap has a much finer wire. The two devices meet in a metal housing. The housing is probably steel - it is magnetic.
Could it be a surge arrester or fuse with the housing acting as a heat sink
What is it likely to have been used for?
Chris
ID:	183561   Click image for larger version
geeoboeh2s is offline
Old 21st May 2019, 7:31 pm   #2
ekjdm14
Default Re: An interesting thermionic device.
I'm probably miles off here, but I thought it could be some kind of spark igniter with the 1mm lead being an electrode and the part below being some kind of current limiting/short circuit protection in case the electrode were to get too close to it's opposite number... As said, likely way off the mark but am also fascinated to learn what it actually is & it's intended use.
ekjdm14 is offline
Old 21st May 2019, 7:35 pm   #3
I'm wondering about the magnetic metal bit - and pondering if it could be some sort of TR-switch for inserting in a waveguide?
(these were designed to ionise very quickly when subjected to a pulse of microwave energy, so providing a short-circuit - often in conjunction with a 1/4-wave of waveguide - across the receiver input to prevent the receiver being desensitized).
If it is a TR-switch imay not have contained a vacuum; TR-switches often used Helium or sometimes even water-vapour.
Old 21st May 2019, 9:10 pm   #4
G8HQP Dave
The bit below the wire looks rather like it has a glass-encapsulated diode inside it. However, I realise that this type of package was used for other devices too.
G8HQP Dave is offline
Old 22nd May 2019, 8:52 am   #5
M0FYA Andy
I've searched the online valve museums, but failed to find anything looking like this.
Andy
M0FYA Andy is offline
Old 22nd May 2019, 10:48 am   #6
Julesomega
Julesomega's Avatar
Maybe the steel housing provided a third internal connection?
- Julian
It's good here
Julesomega is offline
Old 22nd May 2019, 11:37 am   #7
geeoboeh2s
I've added some more pictures taken from different angles.
It looks as though the 1mm wire terminates in a small block inside the envelope. Again this looks coppery but may be the same material as the housing.
I thought that the hole in the housing may contain an Allen screw but I have a reasonable selection and nothing fits.
Chris
ID:	183623   Click image for larger version
ID:	183624   Click image for larger version
Old 22nd May 2019, 11:55 am   #8
GMB
GMB's Avatar
My guess is that it is an X-ray tube.
(There is a very wide range of shapes and styles of these)
GMB is online now
Old 22nd May 2019, 1:07 pm   #9
kalee20
I've seen nothing like this either! However, I doubt that it is thermionic. There aren't enough connections for a heater, and I can't see any any other way of heating a cathode to emitting temperature (eg lens and sun's rays).
There seems to be no getter.
Is there any continuity between the two connections? I'd guess not, but if there is, it could be a vacuum thermistor type of thing.
kalee20 is offline
Old 22nd May 2019, 1:25 pm   #10
geeoboeh2s
If a source gets hot enough it will emit electrons but these will just form a space charge and there will not be a flow of current until a positively charged source is introduced. I perhaps should not have said thermionic without being able to confirm that the wire gets sufficiently hot. However both tubes are evacuated, or at least were.
The tube with the 1mm wire definitely had a getter. Apart from the deposit on the glass due to the loss of vacuum the structure can still be seen inside.
Chris
Old 22nd May 2019, 1:36 pm   #11
I wonder if it's magnetron related?
Old 22nd May 2019, 2:09 pm   #12
barrymagrec
Some sort of possibly incomplete spark gap switch detonator for an atomic bomb?
barrymagrec is offline
Old 22nd May 2019, 5:07 pm   #13
Martin G7MRV
Atomic detonators used Krytron cold cathode switch tubes.
But I think the spark gap idea might be the right way to go, some form of triggered spark gap?
Take a look here http://www.ase-museoedelpro.org/Muse...adar_tubes.htm
maybe a klystron or magnetron but incomplete?
I got food in ma belly and a license for ma telly
My Blog - http://g7mrv.blogspot.com
Martin G7MRV is offline
Old 23rd May 2019, 1:12 pm   #14
Skywave
My guess is some sort of microwave T-R switch: it has that 'certain look'.
Al.
Skywave is offline
Old 24th May 2019, 9:58 pm   #15
Malcolm G6ANZ
Malcolm G6ANZ's Avatar
I've been having a search through Google for this device, as one does. The closest I can see is here:
http://www.electricstuff.co.uk/sparkgaps.html#krytron
Sylvania 1B26
Malcolm
Malcolm G6ANZ is offline
Old 24th May 2019, 11:10 pm   #16
McMurdo
McMurdo's Avatar
A quick google shows some of those radar valves contain radioactive cesium or radium to assist the ionisation threshold.
Kevin
McMurdo is offline
