19th Oct 2015, 12:29 pm | #1 |
Choke test - are these reasonable values?
I have picked up this Igranic C40 Choke but without the benefit of any literature I don't know whether the test values seem reasonable. What do you think?
The Henries reading fluctuates between -3.65 and -4.01H. I didn't expect a minus figure. The reading won't hold steady either. The resistance reading is 15.22M ohms. I was shocked at how high the resistance reads. I know very little about chokes and would appreciate the benefit of your knowledge. Thanks Nick Last edited by SurreyNick; 19th Oct 2015 at 12:48 pm. Reason: Problem with image |
19th Oct 2015, 12:45 pm | #2 |
Re: Choke test - are these reasonable values?
Would that be what your meter does if connected to nothing, perhaps with something touching a lead to add a little mains hum?
Either your meter is broken or your choke is broken, or your are not connecting to it correctly. I would just add that negative inductance is capacitance. If your meter is looking at an open-circuit choke then maybe that is the kind of reading it would show. But check you have the clips attached to the right thing! Last edited by GMB; 19th Oct 2015 at 12:50 pm. |
19th Oct 2015, 1:00 pm | #3 |
The meter seems fine I have tested it against a known item and it was true. With no continuity, whether something is touching one probe or not, the meter returns to 1.
My meter only reads to a maximum of 20H, but when I test it on a 100H choke it just reads 1, so I don't think it can be caused by that either. Addition Yes. I have just checked the meter on a capacitor on the Henries scale and it gave a minus figure. So the choke is almost certainly open circuit too. Last edited by SurreyNick; 19th Oct 2015 at 1:06 pm. Reason: Addition |
19th Oct 2015, 1:12 pm | #4 |
If the 15.22 Mohm reading is correct then the choke is open circuit.
I'd be inclined to remove the crock clips and probe the inductor terminals directly just in case there's a dodgy connection to the clips.
19th Oct 2015, 1:20 pm | #5 |
Thanks Graham. I did what you said and the 15.22 Mohm reading is correct. It seems the choke is duff.
Nick |
19th Oct 2015, 1:23 pm | #6 |
Are you testing the right points? I guessing the two brass lined holes are for mounting screws, but what about the two studs? I'm assuming that only one stud is visible in the picture.
19th Oct 2015, 1:38 pm | #7 |
Yeah I checked those studs Graham. Nothing on them. I came to the conclusion that Igranic used the same casing for a transformer and those would have been used for the additional two terminals. The two brass lined holes are indeed mounting points.
Nick |
19th Oct 2015, 1:46 pm | #8 |
Does it look like it'll come apart easily? If so rewinding looks like a simple job.
19th Oct 2015, 1:53 pm | #9 |
Just about to have a look. I'll let you know. I may be lucky and find the break near the end of the winding.
N. |
19th Oct 2015, 2:52 pm | #10 |
It was so clean inside I'm surprised it's open circuit. I'd swear it was brand new and unused. Just a light layer of rust on the outermost stamping and a slight discolouration to the top layers of cotton thread covering the wire. The cotton was still pure white underneath the outer layers. Sadly I can't find a break near the end of the winding so I suspect it's a rewind job or a new life as a paperweight!
N. |
19th Oct 2015, 3:17 pm | #11 |
That looks like reasonably thick wire, so rewinding by hand is a possibility. You've nothing to lose.
19th Oct 2015, 3:30 pm | #12 |
A task for a winter's evening in front of the telly I think
N. |
19th Oct 2015, 5:23 pm | #13 |
Indeed: which makes me a trifle suspicions of the diagnoses so far.
Nick - this remark may be too late, but better late than never. In my experience, trying to read the resistance of iron-cored inductors of a substantial inductance can often produce a high-resistance indication. Try measuring the resistance again - with a moving coil ohmmeter this time - such as AVO. If that produces a reading in the megohms range, then yes, that choke is definitely O/C. Al. Last edited by Skywave; 19th Oct 2015 at 5:27 pm. Reason: Add quote for continuity & relevance. |
19th Oct 2015, 6:15 pm | #14 |
And try measuring it now the coil is out of the iron.
19th Oct 2015, 6:18 pm | #15 |
Thanks guys. Did a quick check of the coil with my DMM free of the iron and still o/c. In light of this I'm guessing it isn't worth digging my AVO out of the garage?
Nick |
19th Oct 2015, 6:50 pm | #16 |
In that case, Nick, I'd be inclined to state that the coil is O/C.
Of course, there is always the Ultimate Test: connect it to a low-voltage PSU - say 12v. d.c. (you might need a current-limiter in series) - and measure how much current flows in the coil. Zero current obviously proves an O/C: no ifs; no buts; no maybes. Al. |
19th Oct 2015, 7:14 pm | #17 |
Or, to throw a curve ball, test the coil on a capacitance range .....
A short-circuit is equivalent to an infinite capacitance (since the voltage across it will never increase). If there is a break, the two continuous bits of winding either side of it will act as the plates of a capacitor, with the cotton or enamel insulation acting as the dielectric. So if it shows a sensible capacitance, you will know that there is definitely a break.
19th Oct 2015, 7:37 pm | #18 |
I'm pretty sure it's O/C, but I will still try the last two suggestions in the morning and report back. No stone left un-turned.... Thanks.
Nick |
19th Oct 2015, 7:42 pm | #19 |
If you have a piezo electric lighter, try connecting it up to the winding and seeing if you can see a flash in the dark. It's only ever worked for me once but worth a try.
