Old 7th Mar 2019, 11:12 pm   #1
MrBungle
MrBungle's Avatar
Default Panel mount 2 pin male DIN plugs
Got a bit of a weird one here. I nabbed what appears ot be an early 1970s homebrew transverter last year at a hamfest for £1. Looks like it might be 6m. I will work out what it is later precisely. I was initially interested in eviscerating it for parts but it seems a shame to tear it up as it's quite well made.
However the power plug has a broken off pin. It appears to be a 2 pin DIN panel mounted plug which I have never seen before. I've only seen panel mounted sockets before. So in its default state, it would have two pins sticking out of it. Makes sense really as it's safer than having several amps of 12V on the lead end with two pins sticking out!
Does anyone know if these existed or if it was a nifty hack. Also does anyone know here I can get one? I can find inline sockets, but not panel mounted plugs.
MrBungle is offline
Old 7th Mar 2019, 11:26 pm   #2
Bazz4CQJ
Bazz4CQJ's Avatar
Default Re: panel mount 2 pin male DIN plugs
A 2-pin din makes me only think of a speaker plug; one flat pin and one round?
B
Bazz4CQJ is offline
Old 7th Mar 2019, 11:30 pm   #3
MrBungle
MrBungle's Avatar
That's the ones. Trying to find a panel mount plug.
MrBungle is offline
Old 7th Mar 2019, 11:37 pm   #4
Bazz4CQJ
Bazz4CQJ's Avatar
Don't recall ever seeing such a thing; possible to take an end of line plug and fettle it
Bazz4CQJ is offline
Old 7th Mar 2019, 11:38 pm   #5
MrBungle
MrBungle's Avatar
Yeah that's what I may be doing here. This one appears to be a genuine article though. Doesn't look hacked from what I can see. I was going to replace it with an RCA jack but the hole is too big.
MrBungle is offline
Old 7th Mar 2019, 11:51 pm   #6
MrBungle
MrBungle's Avatar
Ok I took it to bits and there's suspicious looking glue in it. looks like this didn't exist and someone put a 2 pin speaker plug shell into a DIN panel mount housing!
MrBungle is offline
Old 7th Mar 2019, 11:52 pm   #7
teetoon
Hello. Yes they certainly existed and I first encountered them on Hacker speakers for the Centurion stereo system back in the early 70's.
Here are a couple for sale. https://www.ebay.co.uk/itm/2-pin-DIN...sAAOSwsDZcMlND
David.
teetoon is offline
Old 7th Mar 2019, 11:52 pm   #8
Terry_VK5TM
Terry_VK5TM's Avatar
I can find the other end, 2 pin DIN female line cord https://vetco.net/products/2-pin-din-female-inline-jack, but the male end seems to be no longer available.
Option - make the hole bigger, fit a blanking plate with a suitable hole for the RCA or other type of connector?
Terry VK5TM
https://www.vk5tm.com/
Terry_VK5TM is offline
Old 7th Mar 2019, 11:54 pm   #9
MrBungle
MrBungle's Avatar
David.
That's the one! Thanks for this
I think the one I have here was hacked up though as it's sticking out of the panel flush with the surface.
MrBungle is offline
Old 8th Mar 2019, 12:56 am   #10
emeritus
They are not in any of my 1970's RS or Ambit catalogues, but are listed in the spring/summer 1971 KJ catalogue . Code 904 in the Audiopacks range, 15p.
Name:	DIN Spkr KJ1971.jpg
emeritus is offline
Old 8th Mar 2019, 11:29 am   #11
Graham G3ZVT
Graham G3ZVT's Avatar
Default Re: Panel mount 2 pin male DIN plugs
Originally Posted by MrBungle View Post
Got a bit of a weird one here. I nabbed what appears to be an early 1970s homebrew transverter last year at a hamfest for £1. Looks like it might be 6m.
If it really is that old it's likely to be 70MHz
We didn't get the 50MHz allocation until 1986.
Graham.
G3ZVT
Graham G3ZVT is offline
Old 8th Mar 2019, 12:23 pm   #12
MrBungle
MrBungle's Avatar
Possibly is. I'm going to reverse engineer it this weekend. It's showing short across rails at moment so I need to get to the bottom of that first. Once it's up I'll get a counter on it and see what it does. I can't read the crystal frequency as it's soldered down. Also the label which probably said what it was stuck down with tape which fell off a long time ago looking at the big square bit of residue.
It's probably scrap but someone put some time and effort into it so I figured it was worth a go at fixing it.
To note it's a downconverter not transverter. It has no transmit chain.
MrBungle is offline
Old 29th Jul 2019, 10:58 pm   #13
MrBungle
MrBungle's Avatar
Back to this at last. It turns out I'm a prize idiot. This isn't a 2 pin DIN. It's a 2-pin Jones plug! I will chuck an opposite gender one in the next Mouser order I do. They still sell new ones for £3 a go.
As suggested by rambo1152, this looks like it was built for 4m. There is a "Jan 73" written in pencil on the side. It looks like the previous owner tried unsuccessfully to convert it to 6m and gave up based on the fact the crystal is, after hooking it out, a 16MHz one and date coded 1984 ((2x16)-18=50) whereas the rest is much older (1969 date code on the MOSFETs!). The short was some bad soldering in the end. The LO works but the multiplier doesn't because the tank coil is at the wrong frequency and the front end dual MOSFET, a 40673 is kaputt. There was no protection so it probably died of static. I may repair it yet and get it on 6m. It just needs a different capacitor and a new MOSFET.
MrBungle is offline
