22nd Feb 2021, 10:10 pm | #1 |
Pye 1005 Achoid
As most people know this record player uses a modified BSR UA16.
The arm is elongated at the back and the arm cannot be raised enough to get at the mounting nut underneath. As far as I can see the only way to remove the arm is by loosening the bearing screw at the side and removing the arm that way. Can someone please confirm. |
23rd Feb 2021, 8:47 am | #2 |
Re: Pye 1005 Achoid
To be specific it is a modified BSR UA15 fitted in the Achioc. Yes, you are correct as to the method of the tone-arm's removal. It has a very limited lift and has no tracking weight adjustment, it being designed exclusively for the Butterfly cartidge.
Edward. |
