Reply
Old 9th Sep 2019, 10:01 pm   #1
Vakito227
Vakito227's Avatar
Default Self Resetting Circuit Breaker with 100 Ohm resistor
Hi all, the Rockola jukebox I'm restoring has a free play button that simulates a 10p coin being dropped into the machine. Someone's modified my machine decades ago to have a 2A fuse in the place of a self-resetting circuit breaker. The coin switches activate a corresponding solenoid to make the credit ratchet go a certain number of clicks. The power to these coin switches passes through the breaker first. I'm wanting to know the purpose of this breaker and whether I should stick with the fuse in its place or attempt to find a replacement?
Thanks!
ID:	189866   Click image for larger version
Vakito227 is offline   Reply With Quote
Old 10th Sep 2019, 4:40 am   #2
Terry_VK5TM
Default Re: Self Resetting Circuit Breaker with 100Ohm resistor
First, either one is there to protect the solenoid (and the rest of the machine) in case the solenoid develops a short or jams or there is some other electronic fault that keeps it activated.
The difference between the two:
If a fuse blows, you have to physically get inside the machine and change it.
If the self resetting fuse trips, it will, as the name suggests, reset itself after a period of time. No climbing inside to change it.
As to which one to use - either, they both perform the same function.
Terry VK5TM
https://www.vk5tm.com/
Terry_VK5TM is offline   Reply With Quote
Old 10th Sep 2019, 6:55 am   #3
Vakito227
Vakito227's Avatar
Hi Terry, thanks for the reply, what's the purpose of the 100Ohm resistor? It's not usually in circuit
Thanks
Peter
Old 10th Sep 2019, 10:22 am   #4
Terry_VK5TM
I'm not 100% sure, but I think either there may have been a different option to enable free play on some jukeboxes or it was for an additional bit of kit like a flashing 'Free Play' sign.
It's been many many years since I had anything to do with jukeboxes, so it's really stretching the memory bank (for others in Oz reading this, think Leisure and Allied Industries).
Terry VK5TM
Reply
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Copyright ©2002 - 2020, Paul Stenning.
