Old 11th Sep 2019, 8:13 pm   #1
Sparky67
Sparky67's Avatar
Default Miniature Crimp RF Connectors / Leads
Hi all,
Does anyone know where the small crimp-on RF connectors are available from, the type used inside the older amateur HF transceivers for inter-board connections?
I need to make up a m-m or m-f lead long enough to extend an existing internal coax so I can start working on repairing a friend's rig.
Thanks
Martin
G4NCE
ID:	189997   Click image for larger version
Sparky67 is offline
Old 11th Sep 2019, 9:45 pm   #2
GSBX1220
Default Re: Miniature Crimp RF Connectors / Leads
Hi Martin,
I think this may be what you are after. https://shop.technofix.uk/connectors...ki-tmp-k01x-a1
Richard
Richard
GSBX1220 is offline
Old 12th Sep 2019, 8:42 am   #3
Sparky67
Sparky67's Avatar
Excellent. Thanks Richard. I will get an order off to Technofix for a male and female connector later today.
Just my luck - although this radio wasn’t with me then, two weeks ago I drove through Abergele!
Thanks again.
Martin
G4NCE
Sparky67 is offline
Old 12th Sep 2019, 9:04 am   #4
Jon_G4MDC
Jon_G4MDC's Avatar
A good find - more tnx!
Jon_G4MDC is offline
Old 12th Sep 2019, 7:16 pm   #5
Sparky67
Sparky67's Avatar
Now I know what they are called, thanks to Richard, I see they are also available on eBay. I obviously wasn't using the right words...!
See 'Taiko Denki TMP-K01X-A1'
Martin
G4NCE
Sparky67 is offline
Old 12th Sep 2019, 10:34 pm   #6
GSBX1220
I could not have told you the name if them, but on seeing the photo of them, it sparked my memory and remembered seeing them a while back in technofix.
Yaesu & trio/Kenwood gear is full of them.
Richard
GSBX1220 is offline
Old 12th Sep 2019, 10:49 pm   #7
Jon_G4MDC
Jon_G4MDC's Avatar
Motorola MC-Micro was my recollection of them...
And I might have some in an FT-70G.
Old 14th Sep 2019, 8:32 am   #8
hpcollector
Also used in the Drake R8 range. Very hard to come by new (well, here at least), I ended up buying a rusty cruddy old ICOM HF rig just to get the cables to use for alignment work.
hpcollector is offline
