Old 21st Jul 2018, 7:53 am   #1
Nonamebrand
Default Help ID old rf power amp
Hi
Im new and not very knowledgeable, and have an old rf amplifier that I cannot find information on. It’s a TPL Communications Inc. PA3-1DE R. There’s a picture attached. How old is this thing? Is it ok to try it out? Thanks for taking the time!
Nonamebrand is offline
Old 21st Jul 2018, 11:12 pm   #2
Default Re: Help ID old rf power amp
Difficult to read that label, but it appears to be a fixed frequency VHF (136 MHz aircraft band?) amplifier.
Without a suitable dummy load rated for its output power and a suitable drive source and dc power supply to feed it you can't do anything sensible with it anyway. It's no use for anything legal for a private individual as it stands though a licensed radio amateur might be interested in it to modify, perhaps.
Edit: https://www.tessco.com/products/disp....do?sku=575663
provides a bit more info re spec etc and it looks like it could well be used for the 144 MHz amateur band as it is.
If the info from the link doesn't mean anything to you, then it's still no use for anything legal for a private individual though a licensed radio amateur might well be interested in it.
Herald1360 is offline
Old 22nd Jul 2018, 9:00 am   #3
I certainly wouldn't try it out on those frequencies. It looks like it's tuned for what is an air/ground comms channel.
These are probably the most thoroughly policed frequencies on earth. Leak even a fraction of its power and you'll likely get official visitors to shut it down and confiscate equipment.
As said, radio amateurs have a frequency assignment nearby and often shift these things to those frequencies. They turn up at amateur radio flea markets for scrap prices. so they're a cheap way to make a big signal.
Radio Wrangler is online now
Old 22nd Jul 2018, 10:23 am   #4
dodgy-dxer
dodgy-dxer's Avatar
Why not use Google?
You would have found this
http://www.tplcom.com/pdf/2013brochure.pdf
Fred
dodgy-dxer is online now
Old 22nd Jul 2018, 1:55 pm   #5
kan_turk
kan_turk's Avatar
A closer look at the equipment label reveals frequency range of 136 - 174 MHz which agrees with link above - so all perfectly legal for a licensed radio amateur or indeed anyone licensed to operate on frequencies within this range eg marine but not otherwise
J
kan_turk is offline
Old 22nd Jul 2018, 4:31 pm   #6
Better eyesight than me! The 6 is bold, but I thought it was a decimal after it. Makes more sense as a dash!
Legal for amateur use in 144-146 MHz, but although it covers the marine VHF band, only type-approved equipment is usually legal there. Is it 146-148 in Canada?
