Old 11th Jan 2018, 2:07 pm   #1
MALC SCOTT
MALC SCOTT's Avatar
Default Regentone BT17 Driver transformer.
Hi, anyone got a spare output t/x for this transistor radio? Cheers, Malc.
Malc Scott
MALC SCOTT is offline   Reply With Quote
Old 11th Jan 2018, 3:16 pm   #2
Diabolical Artificer
Diabolical Artificer's Avatar
Default Re: Regentone BT17 output transformer.
Haven't got the exact one Malc but may have something suitable. What are it's specs/physical size? I have a couple of RS midget/minature OPT's if of any use., and several matching tfmr's.
Andy.
Diabolical Artificer is offline   Reply With Quote
Old 11th Jan 2018, 3:27 pm   #3
ukcol
ukcol's Avatar
The Regentone BT17 doesn't have an output transformer Malc - it does have an audio driver transformer. Have you given use the right model number?
Best Regards, Colin McLaughlin
BVWS Member
ukcol is offline   Reply With Quote
Old 11th Jan 2018, 3:53 pm   #4
MALC SCOTT
MALC SCOTT's Avatar
Sorry, I should have said driver transformer.
Malc Scott
Old 12th Jan 2018, 9:30 am   #5
Default Re: Regentone BT17 Driver transformer.
As I said Malc, I have several NOS RS minature tfmr's that should do the job. I'll see if I can find the turn's/Z ratio; any idea of yours?
Andy.
Old 12th Jan 2018, 9:48 am   #6
MALC SCOTT
MALC SCOTT's Avatar
Hi Andy, the cct diag states the primary winding is 200 ohms and both of the secondarys are 43 ohms. Hope this info helps, Malc.
Malc Scott
Old 12th Jan 2018, 3:33 pm   #7
Hi Malc, the one i found is a RS driver tfmr 1:1 ratio. Measured windings are 68 and 80 ish ohm's DC res. Pri is two terminal, sec is centre tapped, (yours from schematic is two separate windings) but one leg read OC. Size of this and other similar tfmr's I have is 3/4 X 5/8 x 5/8" approx. I'll have another look tomorrow and see what else there is.
A.
Old 12th Jan 2018, 4:52 pm   #8
Ed_Dinning
Hi Malc, yours is probably a 3to 1+1, or 4 to 1+1
Ed
Ed_Dinning is online now   Reply With Quote
Old 13th Jan 2018, 5:56 am   #9
Thanks Ed, gives me a better idea what to look for.
A.
Old 13th Jan 2018, 12:58 pm   #10
Gone through them all Malc and can't find one that'll suit, sorry.
A.
Old 13th Jan 2018, 2:59 pm   #11
MALC SCOTT
MALC SCOTT's Avatar
Thanks for looking Andy.
Malc Scott
Old 20th Jan 2018, 11:43 am   #12
MALC SCOTT
MALC SCOTT's Avatar
Still looking for one, Malc.
Malc Scott
Old 21st Jan 2018, 6:33 am   #13
Hammond do a good range of tfmr's Malc - https://www.hammfg.com/electronics/transformers/audio
A.
Old 22nd Jan 2018, 8:16 pm   #14
Biggles
I've just been looking at audio transformers at RS and they do some small interstage types. The part number is 210-6368, but this is for an E187A. If you look at the associated table there is a type E187B which looks like it may have two seperate secondary windings. Might be worth a look at as they are small enough in size. Not cheap though.
Alan.
Biggles is offline   Reply With Quote
