6th Sep 2018, 5:45 am | #1 |
Antrim transformer specs
Hello all,
I have an Antrim toroidal transformer that has a number, but I cannot find any specifications for it. Apparently it was taken out of an English phono pre amp ( phono ? ) kit. The part number is 3588CMP It is dated 3/97 There is a number after the Antrim name in brackets, but maybe its a phone number? (01849 428734 ) it has two primaries of I guess 115 volts, or perhaps 120 volts one high voltage secondary one low voltage secondary Does any body have any data for this unit. I can always use my own deductions and they are as follows: It appears to be a standard core diameter of "either" 60 watts, or 80 watts. It has an external flux band so hence that bit of the confusion,the insulation thickness, and the thickness of the flux band can vary. Also the flux density could fit either toroid diameter. low voltage secondary wire guage is 1.15mm high voltage secondary wire guage is .35mm Primary wire guage is .25mm I can rate the traffo "roughly" from the wire guages and core diameter, but I thought maybe somebody here could help? Thanks in advance Joe |
6th Sep 2018, 9:43 am | #2 |
Re: Antrim transformer specs
I can’t help you with transformer specifications, but if you get no joy from other forum members this may help. Antrim acquired by Trans-Tronic, of Derbyshire, UK in 2008, email: enquiries@trans-tronic.co.uk.
Cheers John |
6th Sep 2018, 5:51 pm | #3 |
I have a couple of NOS Antrim toroids - the purchaser of Antrim supplied the essential data by return email a week or so ago - they couldn't supply full data, but gave me what they had very quickly. Just drop them an email.
Alan |
