21st Feb 2014, 1:58 pm | #1 |
Explosion Proof Light?
Still about collecting junk & stuff I like, anyway I think these are probably ex-mod and even common, but I don't know what light they are from, I suspect explosion Proof type lights, but I don't know, as I can only ever seem to find the screw in type glass, anyone know?
Just under 8"x 4 1/4" |
21st Feb 2014, 4:36 pm | #2 |
Re: Explosion Proof Light
I don't think glass would be used for an explosion proof light though. Radio mast lights?
21st Feb 2014, 5:29 pm | #3 |
Turn them into giant "LED" lookalikes and use them for Christmas decorations / talking points.
Have you got an empty fireplace that needs cheering up?
21st Feb 2014, 6:01 pm | #4 |
Could be for emergency warning lights over doorways, keep out areas etc?
BVWS member |
21st Feb 2014, 8:38 pm | #5 |
I understood that "explosion proof" as applied to electrical apparatus does not necessarily mean that it is capable of withstanding an explosion, but means that it can be used in an explosive atmosphere without the risk if initiating an explosion. They look like the glass cover to our outside light, which is clear, and has a flange and gasket for keeping it in place and keeping out the rain. It was already installed when we moved in more than 30 years ago.
21st Feb 2014, 9:10 pm | #6 |
They look a bit like the lenses used on rotating beacons fitted to emergency vehicles etc. but red rather than blue or orange. A bit taller though. What are they made of?
21st Feb 2014, 9:36 pm | #7 |
I think you're right, 'EX' rated beacons. I'm sure I've seen them surrounded by a protective cage. Somewhere like a refinery, airport, gasworks or coal mine. They would have been extortionately expensive...modern LED versions are around £800 a pop
Kevin |
21st Feb 2014, 9:41 pm | #8 |
I side with posting #2
21st Feb 2014, 11:13 pm | #9 |
There's a light with a red glass dome that looks very much like these on the end of Bournemouth pier, to warn shipping that there's a pier sticking out into the sea!. They look like a red version of the Coughtree dome.
21st Feb 2014, 11:48 pm | #10 |
If the glass is "ruby" glass, then they could be used as safelights for photograpic B/W processing, not that there's much call for this sort of thing these days.
22nd Feb 2014, 12:29 pm | #11 |
I would say they're off old radio mast navigation lights, the ones that took an incandescent lamp beneath and have since been replaced by LED units. I have seen several of this size being chucked out from various places.
Regds, Russell W. B. G4YLI. |
22nd Feb 2014, 1:23 pm | #12 |
I guess that means they're not "Other Vintage Household Electrical or Electromechanical Items" then
22nd Feb 2014, 1:42 pm | #13 | |
22nd Feb 2014, 5:14 pm | #14 |
They are old Mast marker light lenses, ex RAF. Be interested to know where they came from, I know of only one source locally.
22nd Feb 2014, 6:30 pm | #15 |
A shop in Hitchin, like all my other old MOD stuff.
23rd Feb 2014, 9:44 am | #16 |
The red one reminds me of the lamps that one saw on some electricity poles in parts of NZ back in the 1950s. They were fitted on those poles that also carried those red circular fire alarms (of the break-the-glass-and-press-the-button type), presumably to make them (the alarms) easier to find at night. The lamps were mounted below the electricity wires, and my recollection is that typically they were fitted at the end of a tube cantilevered horizontally out from the pole and bent downwards at around 30 degrees just before the lamp base. So the glasses also had the same slant.
Cheers, |
