9th Nov 2018, 2:30 pm | #1 |
Weller WECP Temtronic bit advice please
I have recently obtained a used Weller WECP Temtronic soldering iron. This unit can be set to a wide range of temperatures by adjusting a pot on the front panel, rather than by changing the bit as in the older TCP range that I have used for more than 50 years. I would like to obtain another, larger chisel bit for the WECP, for heavier work.
The heating element on the iron is identified as an ECP. I am having trouble specifying the bit type as my searches for ECP tips do not come up with bits (tips) that look correct. I have attached photos of the base unit, label and the iron, bit and holder. I wonder if anyone recognises it and has the correct information to specify the bit type. Thanks Ron Last edited by ronbryan; 9th Nov 2018 at 2:35 pm. Reason: Iron close-up photo added |
9th Nov 2018, 3:51 pm | #2 |
Re: Weller WECP Temtronic bit advice please
The element end of the bit is hollow and a probe from the soldering iron element tube slips inside and possibly senses the temperature.
Ron |
9th Nov 2018, 4:27 pm | #3 |
It looks like my old Weller Thermolock iron tip. Yes the sensor slips just inside the end of the tip.
A quick google shows the 'ET' series bits offered as suitable for the LR 21, FE 50, WEC, thermolock, EC2000 and EC2100 irons, so presumably any of those would fit. https://uk.farnell.com/weller/et-b/t...-4mm/dp/416770
Kevin |
9th Nov 2018, 4:32 pm | #4 |
If this is the model I think it is I seem to remember that it takes bits that are virtually identical in size to the TCP bits but without the magnetic slug and a deeper hole for the sensor to fit.
I think these may be the type :- https://uk.farnell.com/w/c/tools-pro...ange=et-series I have a couple of 4ETP-1 bits bought in error which you could have to prove the point if you like. Last edited by barrymagrec; 9th Nov 2018 at 4:41 pm. Reason: corrected link |
