20th Mar 2018, 12:09 pm | #41 |
Re: Vibrational effects on vintage hifi components
I do wonder if the 'unrecoverable' error rate of a CD drive increases with a realistic vibration level ?
I know from experience with audio CD’s, using multiple different computer CD / DVD drives, the unrecoverable read error rate is distinctly non-zero but this occurs without vibration and, typically, the drives are trying to read at a much higher speed. Mostly, re-reading multiple times (eg cd-paranoia) can get uncorrupted data off the disk but the drive itself certainly won’t be doing that by itself and I assume a simple CD player built on such technology won’t be doing it either … dc |
20th Mar 2018, 12:12 pm | #42 |
Yes, I knew you (Radio Wrangler) know how it works but there will those reading who might think your thought experiment involving a massive mechanical PLL could be taken seriously. That is the problem with the internet: it can be impossible to tell the difference between a joke and nonsense unless you know where the author is coming from.
20th Mar 2018, 5:54 pm | #43 |
Aye, that's the problem with hifi. There will be people somewhere who would take anything seriously. I remember someone in the US going round saying he'd suggested the green-pen treatment of CDs as a joke and was bursting a gut trying to get people to believe it was only a joke. But was he real?
At least I held off short of suggesting the all-valve CD player (rather than one token one at the end of the audio chain...) David
20th Mar 2018, 8:04 pm | #44 |
You could really go steam punk and have a fluidic triode based CD player
20th Mar 2018, 10:58 pm | #45 |
I'm sure I saw somewhere someone asking about a valve based CD player. Presumably someone who thought that 16-bit audio data comes straight off the disc, and hasn't really thought about how to make a 16-bit DAC using valves.
21st Mar 2018, 2:41 pm | #46 |
I think there was one in the dim and distant past. But as has been said, it was probably just a single double triode proudly mounted 'above decks' and just acting as an amplifier, and there only to appease the audiophool 'valve man'.
21st Mar 2018, 3:39 pm | #47 | |
Cheers, GJ
http://www.ampregen.com |
21st Mar 2018, 4:15 pm | #48 |
And running below the 50v SELV limit...
21st Mar 2018, 5:06 pm | #49 | |
One day I will pop in and ask why they are "so good" and revel in the bull excreta delivered. Mind you they are very pretty and expensive! |
21st Mar 2018, 6:25 pm | #50 | |
Cheers, GJ
21st Mar 2018, 7:33 pm | #51 |
Errr, what is the Ft of a fluidic triode?
21st Mar 2018, 7:48 pm | #52 |
Back in the day, output valves were very often exposed, and run very hot. The main risk was thought to be voltage, so the Radford STA25 had a cage over the transformers but the valves were exposed to all and sundry. Quad also had the valves in air, but had transformers that had the terminals coming out the bottom - so were below chassis.
Nowadays, there seems to be a mix of completely enclosed with ventilation perhaps with fan cooling, exposed but with a vestigial cage over the output valves, and totally exposed. I have no idea how they get around regulations. Looks like the maximum temperature for exposed and touchable glass and ceramics is 80C, set by IEC regs. Since the envelope temperature of an EL34 (and other power valves like the KT88/6550) is 250C I'd say that an audio amplifier with exposed power valves would have a hard time getting through CE testing! Craig |
21st Mar 2018, 7:49 pm | #53 |
21st Mar 2018, 8:19 pm | #54 |
Quad's modern valve amps come with valve cages https://www.audioemotion.co.uk/ekmps...1;3]-802-p.jpg. They also come with a long screwdriver to remove the cage, as you need to to replace a valve. If you then choose to run the amp without the cage, well, that's up to you.
Cheers, GJ
21st Mar 2018, 9:43 pm | #55 |
I keep suggesting the 3-500z triode as a wonderful audio valve. It ticks all the boxes:
Gorgeous looks Triode Glass Lights up Directly heated. Plenty of power Wimps need not apply Reassuringly expensive even before the audio brigade move in But my ulterior motive is that with about 2kV on the top cap, they might thin the ranks of the audiophiles and lessen the price pressure on simple receiving valves. David
21st Mar 2018, 10:30 pm | #56 |
The slightly smaller 304TL, also by Eimac, is quite often used to make audio amps. Here is one of the more ambitious designs built around it http://www.amberwaveaudio.com/design-specifications.htm. It weighs 200lbs, and you'll need two of them since they're only mono.
Cheers, GJ
21st Mar 2018, 11:34 pm | #57 |
27th Mar 2018, 1:57 pm | #58 |
Try purchasing four packets of lemon jelly, remove from the cardboard outer but leave them in the transparent water proof shrink wrap.
You then stand each support pad of the hifi unit under test on one of the packets. If it makes no improvement then you can eat the jellies, or maybe try different flavours. Bit early for April 1st I suppose. |
27th Mar 2018, 2:35 pm | #59 |
The only valve CD Player (output stage only, by the looks of it) that springs to mind is the Jolida JD100 ... An internet search shows reviews & all sorts ...
The metal chassis may provide a rigid base to reduce vibration, not sure the standard looking mech has anything to offer in this regard. Just imagine an all valve CD player though, the sheer size of it Mark |
27th Mar 2018, 3:40 pm | #60 | |
