Reply
Old 20th Nov 2023, 7:45 pm   #1
Gary5117
Default Pye P114BQ
Hi everyone.
I'm trying to understand radio schematics and I wondered if anyone could help with the description of this PYE radio cct in which it says the volume control acts as a diode load. What is a diode load, why do we need one? Your help is much appreciated.
Name:	Pie P114bq volume control IMG_20231116_175105546.jpg
ID:	288466   Click image for larger version
ID:	288467   Click image for larger version
The more I find out, the more I know how much I don't know!
Gary5117 is offline   Reply With Quote
Old 20th Nov 2023, 8:22 pm   #2
PJL
Default Re: Pye P114BQ
Without a 'load', the AC signal rectified by a perfect diode would pass just half cycles of the AC carrier signal but in this circuit and without the 'load' it would discharge C18 leaving it to rest at a -ve DC corresponding to the AC carrier voltage peak. The volume control acts as a load on C18 and discharges the capacitor but slowly enough to filter out the unwanted carrier frequency but not fast enough to remove the audio.
PJL is offline   Reply With Quote
Old 21st Nov 2023, 3:10 pm   #3
Gary5117
Ah yes, that makes sense I put a capacitive dropper in a champion radio and couldn't understand why the rectified B+ wasn't getting up to the required voltage. It turned out that the capacitor was only working in part because it was also feeding the valve heaters which I guess were acting as a capacitive load....but not enough.
That is so helpful
Thank you
Gary
Old 21st Nov 2023, 3:32 pm   #4
Cobaltblue
Cobaltblue's Avatar
If you have not already seen it there is some additional information on this subject here:
https://www.vintage-radio.com/repair...rf-stages.html
Including a nice drawing that shows what PJL describes.
A lot of good reading here:
https://www.vintage-radio.com/repair...ion/index.html
Mike T
Don't care if it was a bargain why's it in my kitchen
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is online now   Reply With Quote
Old 21st Nov 2023, 3:56 pm   #5
Gary5117
In this cct is it also doing the same for C19?, and does the 10Mohm Resistor R8 do the same for C20?
Thanks
Old 21st Nov 2023, 3:58 pm   #6
Gary5117
Thanks Mike T I will have a look.
Reply
