Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Offered and Wanted Messages > Sets, Parts and Service Information Wanted (private buyers only, no swaps)
Sets, Parts and Service Information Wanted (private buyers only, no swaps) If you need help obtaining components, sets or equipment, post a message here. Private buyers only - no traders. No swaps.
Reply
Old 15th Nov 2023, 4:20 pm   #1
Paul-Harrison
Default Contamination meter No 1
Good afternoon
I have a number of contamination meter No. 1's some operational, what I cannot find is circuit / service information on the power supply units vibrator 666-110029 and mains 6665-110028 can anyone help? Regards Paul G8ADY
Paul-Harrison is offline   Reply With Quote
Old 15th Nov 2023, 4:59 pm   #2
TonyDuell
Default Re: Contamination meter No 1
I couldn't find anything official either, but I've attached the circuit diagrams that I traced out from my units.
Be warned that the mains supply is potentially lethal. One of the (easily touched) sockets on the top is directly connected to the red (live) wire of the mains cable!
File Type: pdf Meter_Contamination_No1_PSU_Circuits.pdf (611.0 KB, 88 views)
TonyDuell is offline   Reply With Quote
Old 15th Nov 2023, 5:45 pm   #3
Paul-Harrison
Hi Tony
many thanks, that must have taken a while! The mains unit is even simpler, a sealed main tx diode rectifier and cap, with fused op. As for keeping the fingers out of the way, don't worry, I started my working career in radio & tv some 60 years ago, when it was all like that! Regards Paul
Old 16th Nov 2023, 10:58 am   #4
TonyDuell
You did notice that page 2 of the .pdf shows the mains unit I have. It's much the same as yours, a mains transformer, selenium stick rectifier and smoothing capacitor. But my fuse is on the mains side.
It didn't take me that long to draw the circuits out, I've done things a lot more complicated than that!
As for safety, I am used to dealing with mains on what I expect to be mains terminals. And with live chassis sets which are safely encased when in use. But I do not expect an exposed brass socket on the outside of a unit to be directly connected to mains live.
Old 16th Nov 2023, 12:15 pm   #5
Paul-Harrison
Morning Tony, Sorry you are correct, I've only recently acquired the mains PSU, I've been looking for quite some time for one, only just investigating! I agree with about the live terminals at the base of the PSU as this can be removed from the main body by the operator still powered from the mains and NO warning signs!!
Old 16th Nov 2023, 11:07 pm   #6
Uncle Bulgaria
Uncle Bulgaria's Avatar
TonyDuell's circuit diagrams were vital in repairing the one I got hold of (using Ukrainian Soviet capacitors to replace the leaky ones). I've attached some other technical details that you may find handy.
Uncle Bulgaria is offline   Reply With Quote
Old 17th Nov 2023, 12:08 pm   #7
Paul-Harrison
Good morning, many thanks for your info, Tony's PSU circuits are a great help, its strange there appears to be no Info available for the two PSU units, Tony's comments about the dangers of the mains unit, the more I looked at it, more I thought what a dangerous bit of kit! I am considering putting an inline RCD on the input cable. I have two working meters, one with the Plessey connectors and one with the rubber connectors. I did the cap and diode changes some years back, I found a company in Canada "just radios.com" they do a wide range of HV caps and other bits. I have also re-built a duff CV2247 using the original rubber housing and packing in a Russian SB-180G tube, which works quite well, but I cannot seem to find them anymore.
Regards
Paul
Old 17th Nov 2023, 12:35 pm   #8
Uncle Bulgaria
I've not seen a mains unit but they sound very dodgy! I guess the only use for it would be testing as field use would require the original batteries. The manual does show a stationary use case where personnel are being checked as they pass the detector, perhaps into a shelter.
I use mine with a vibrator supply on AA batteries, with a CV2247 from Langrex as the original was duff. I have one of the other type with the removable cap, which the manual says is for testing water for radioactivity, but that's defunct. GSTube has several Soviet geiger tubes including an SI-180G, but I'm not sure how advisable it is buying from Russia at the moment.
I think it's preferable to restrict serious use of such things to computer games like Fallout, whose retro-futuristic outlook I'm thoroughly enjoying!
Old 17th Nov 2023, 6:08 pm   #9
m0cemdave
Interesting to see those old STC "Unistor" or "Q-type" rectifiers in the voltage multiplier stack. I have a box of assorted types lurking around here somewhere.
m0cemdave is offline   Reply With Quote
Old 18th Nov 2023, 12:06 pm   #10
Paul-Harrison
Hi, many thanks for that information, I have been a mystified at what type of rectifier/diode type there are, I found some info which shows an advert from 1953 for the Unistor, and I believe it to be a Q3/3 because of the two orange bands, thanks Paul
Old 18th Nov 2023, 9:06 pm   #11
m0cemdave
Yes, it looks like a Q3/3.
I'm not sure where I dowloaded this info from - possibly posted on here by somebody a year or two ago - but it may be of interest:
Name:	STC Q rectifiers.jpg
Old 19th Nov 2023, 11:24 am   #12
Paul-Harrison
Many thanks for that, now it ties up with the No1 parts list info. This is hard to find data!
Reply
