Reply
Old 20th Oct 2023, 11:42 am   #1
Tractionist
Default Stuck IFT cores
Hi All -
I'm currently looking at a pair of Perdio 'Piccadilly' trannies - both of which seem to be pretty deaf. (I've been all the way through one and re-capped it etc.). The 'final touch' was going to be an alignment check but ....... the Toko style IFT cores [they aren't Toko by the way] in both sets seem to be pretty much 'stuck' - complete with perished rubber locking threads pretty much disintegrated too (but doubtless still inside the core tube etc.).
So ..... my question is: what is your favoured method of freeing-off these cores without causing unnecessary damage?.
Red to red, black to black. Throw the switch and stand well back!
Tractionist is offline   Reply With Quote
Old 20th Oct 2023, 5:08 pm   #2
G6Tanuki
G6Tanuki's Avatar
Default Re: Stuck IFT cores
When you say "Toko style" IFTs, do you mean the small quare stamped-brass cans with a hole in the top through which you can access a broad slot in the upper part of the ferrite pot-core?
Usually with different colours on the cores [red, yellow, green] to distinguish the function?
Have never seen these with rubber locking filaments, the adjustable locking was in my experience done with wax.
Perhaps you could try gentle heat?
TURN IT UP! [I can't hear the Guitar] - TMBG.
Old 20th Oct 2023, 5:16 pm   #3
radiomobile
I have never encountered Toko IF transformers with locking threads. The type in the Perdio Piccadilly look more like Weyrad design in which case be very careful not to crack the cores which will be very difficult to fix.
Assuming the core is not cracked the best approach I have found is first to apply heat, as much as you dare without causing collateral damage, then a couple of drops of white spirit and leave for a few hours in a warm place. A proper trim tool which fits accurately is a must. If they are the Weyrad design they sometimes have very small polystyrene caps inside the can which have been known to fail.
If the radios are very deaf it is unlikely that core adjustment is the only cause.
radiomobile is offline   Reply With Quote
Old 21st Oct 2023, 7:24 pm   #4
buggies
buggies's Avatar
The transformers were made "in house". I think that in the PR7 they were only accessible from the top as the pcb covered the bottom. The slots go the length of the cores and require the correct (copper) tool. They are very fragile and virtually impossible to remove without damage once cracked.
I suggest that it might be wise to assume that they have not been tweaked by the phantom and are aligned exactly as they left the factory.
George
buggies is offline   Reply With Quote
Old 21st Oct 2023, 9:16 pm   #5
newlite4
newlite4's Avatar
Dribbling a little bit of lighter fluid (naptha) into the threaded core generally works for me. It is enough to free off any stubborn wax and other forms of stiction and it dries off quickly with no residue.
Neil
preserving the recent past, for the distant future.
newlite4 is offline   Reply With Quote
Old 7th Nov 2023, 9:23 am   #6
FrankB
I have had good luck heating a metal rod of the correct size and applying it to the core.
On the hex core types, I use a sacrificial metal hex wrench heated dull red inserted in the hole maybe 5 seconds, then use a correct size plastic or wooden adj tool.
I have also used a heat gun with the correct size tip as well as my new hot air desoldering station with the correct size tip. That takes a bit of practice though.
(Of course, if I screw up and break the core, I have a drawer full of cores I saved over the years from scrapped radios & TV sets as replacements. It seems to be perfectly fine to grind down a too long replacement core to the correct size also. At least I never had a problem with this).
FrankB is offline   Reply With Quote
Reply
