Old 22nd Feb 2022, 1:54 pm   #61
cathoderay57
Default Re: Useful tuning scale and label scans etc
Final versions of Murphy A48 dial legends in forward and reverse print attached.
Last edited by Cobaltblue; 23rd Feb 2022 at 10:32 am. Reason: Previous draft post removed, request removed :)
cathoderay57 is offline   Reply With Quote
Old 22nd Feb 2022, 11:08 pm   #62
Nanozeugma
Nanozeugma's Avatar
Originally Posted by cathoderay57 View Post
Final versions of Murphy A48 dial legends in forward and reverse print attached. Mods please remove previous post including draft.
Grateful thanks to Jerry who generated these at my request to solve the problem of replacing a much degraded / distorted original.
Thermionic Emission, warms the cockles of your tubes.
Nanozeugma is offline   Reply With Quote
Old 13th Jul 2022, 5:18 pm   #63
PJC58-Hythe
PJC58-Hythe's Avatar
Here are another couple of recreated dials for the EKCO SH25
Peter - M0HYT - BVWS Member - GQRP Club
http://www.retroworkshop.co.uk
PJC58-Hythe is offline   Reply With Quote
Old 3rd Feb 2023, 2:44 pm   #64
PJC58-Hythe
Another couple of dials to add to the ever growing list..
Please note: When printing from these PDF files make sure you select 'Actual Size' and not the default of 'Fit' or they will be the wrong size!
As the Milde 541 is printed on the glass I have created one that can be placed on the backplate by first removing the tuning indicator and the band indicator.
Old 6th Mar 2023, 10:56 pm   #65
Nickthedentist
Nickthedentist's Avatar
Not a dial, but the paper label affixed to the chassis of the Pilot Major Maestro (Model T16) from c. 1947, the version with a live chassis but with a stepdown filament transformer.
With all the postwar shortages, they seem to have been a bit approximate with the label applied; this one clearly states it's for the multi-voltage version, but it was applied to a 240V~ only chassis.
Name:	Pilot T16 label.jpg
Nickthedentist is online now   Reply With Quote
Old 7th Mar 2023, 2:36 pm   #66
David G4EBT
David G4EBT's Avatar
I had a dial scan of a KB FB10 'Toaster' in which - due to the thickness of the glass when scanning - shadows were cast in the areas of the dial which should be transparent, such as where the wavelengths are marked, and the little oblong 'windows' adjacent to the station names. Those shortcomings will be noticeable when viewing the original scan, Pic 1 below, and were also apparent on a waterslide transfer.
I've found some time to clean up the scan by clearing all the transparent areas, and have recreated the wavelength markings in the windows, which had been a bit indistinct. A waterslide transfer applied to the rear of the dial glass needs to have the image reversed and must of course be printed on transparent decal paper so that the 'window' areas are transparent.
Pic 1: The original scan.
Pic 2: The cleaned up scan.
Hope that might be useful to someone.
Name:	KB FB10 Dial Scans.jpg
ID:	274521   Click image for larger version
Name:	KB FB10 Dial Scans Retouched.jpg
David.
BVWS Member.
G-QRP Club member 1339.
David G4EBT is online now   Reply With Quote
Old 7th Mar 2023, 4:20 pm   #67
Nickthedentist
Impressive, David, thank you.
Old 30th Aug 2023, 9:58 am   #68
David G4EBT
I've just discovered that there are these dial and logo scans too:
https://www.vintage-radio.info/scans
David.
BVWS Member.
Old 13th Sep 2023, 4:51 pm   #69
Dickie
Another Ekco AD75 scan. It's always good to have a choice!
Richard, BVWS member
Dickie is offline   Reply With Quote
Old 1st Nov 2023, 8:56 am   #70
PJC58-Hythe
Ekco AD76 recreated dial
