Old 3rd Jan 2015, 1:04 pm   #1
vu2nan-nandu
vu2nan-nandu's Avatar
Default Audio Signal Injector
Another useful test gadget!
http://nandustips.blogspot.in/2012/0...-injector.html
Regards,
Nandu.
https://nandustips.blogspot.com
vu2nan-nandu is offline
Old 3rd Jan 2015, 3:24 pm   #2
unitaudio
Default Re: Audio Signal Injector
Thanks, very useful indeed and beautifully simple.
Regards,
Paul
...No, it's not supposed to pick up the World Service, it's not a radio!
unitaudio is offline
Old 3rd Jan 2015, 3:52 pm   #3
paulsherwin
paulsherwin's Avatar
If you use silicon transistors it will produce higher frequency harmonics, better for RF/IF work.
paulsherwin is online now
Old 3rd Jan 2015, 10:00 pm   #4
jimmc101
jimmc101's Avatar
This circuit relies on the leakage current of the germanium transistors to work. (It probably makes a good audio thermometer.)
With the much lower leakage current of silicon devices, resistors from base to -ve supply for each transistor would be required for it to function (220k?)
Jim
jimmc101 is offline
Old 3rd Jan 2015, 10:22 pm   #5
paulsherwin
Yes, you're quite right.
Old 5th Jan 2015, 4:31 pm   #6
G8HQP Dave
Could I perhaps suggest that VU2NAN should just post one link to his home page, instead of starting lots of threads here and elswhere (e.g. DIYaudio) to promote individual pages on his website? If we all did what he is doing then forums would rapidly fill up with personal adverts instead of discussion.
G8HQP Dave is offline
Old 6th Jan 2015, 6:42 am   #7
vu2nan-nandu
Hi OM Dave,
I agree with you.
Thank you.
73,
Nandu.
Old 7th Jan 2015, 7:21 am   #8
vu2nan-nandu
Many thanks, Paul!
Regards,
Nandu.
Old 7th Jan 2015, 3:27 pm   #9
Ian - G4JQT
Ian - G4JQT's Avatar
Am I missing something, or is the circuit in the OP just a PNP astable multi-vibrator? Not sure it would even work without any proper bias on the bases. Must be relying on leakage through the capacitors!
Here's a more reliable design using any cheap NPN silicon transistors. Change C1/C2 to change frequency.
As Paul says in post 3, modern silicon transistors will also be better for IF/RF work.
Ian
Name:	astable multivibrator.jpg
Ian - G4JQT is offline
Old 7th Jan 2015, 7:04 pm   #10
vu2nan-nandu
Hi OM Ian,
It's just that. Base bias is not required on account of Germanium transistor junction leakages.
That's what makes the circuits using Germanium transistors simpler.
73,
Nandu.
Old 7th Jan 2015, 8:12 pm   #11
Ian - G4JQT
Yes, perhaps, but the leakage is likely to be unreliable. It may work with some AC125 transistors, but not others.
I've never seen a germanium transistor multi-vibrator circuit without some base biasing resistors to ensure consistent and reliable operation.
I'm not sure that hoping a circuit will function on a variable (and not usually desirable) parameter like internal leakage is necessarily good design practice...
Ian
Old 7th Jan 2015, 8:25 pm   #12
Nickthedentist
Nickthedentist's Avatar
...but perfectly OK for simple homebrew circuits, surely.
Nickthedentist is offline
Old 9th Jan 2015, 2:26 am   #13
Oldcodger
I've always used a Cmos gate oscillator giving at original frequency something on the audio range works well into the RF range. First one I built was to fault a radio board. I'd bought two non working boards to make one for a project. Worked a treat into the RF range.
Oldcodger is offline
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Copyright ©2002 - 2020, Paul Stenning.
