15th Feb 2024, 1:22 pm | #21 |
Re: PM 5519 pattern generator
Great news that you found the fault!
Re the transistor array, perhaps one of the transistors failed when the can of C533 shorted across to one of the feed resistors. You could do a junction check with your multimeter (diode test) referring to the circuit diagram for the relevant transistor bce connections. Regards, Symon |
15th Feb 2024, 7:40 pm | #22 |
Setting the external power supply to about 0.8 volts and its current limit to (say) 250mA should be fairly safe. Then measure around the various -12v points to find the lowest mV point?
George |
15th Feb 2024, 8:07 pm | #23 |
I won’t need to do that now. As,with help, I found the fault. It there is still more to do as the output voltage is way too small
15th Feb 2024, 11:19 pm | #24 |
Duh! - sorry about that - Was looking at the cached web page without refreshing.
George |
16th Feb 2024, 10:00 am | #25 |
No problem. All help and advice gratefully received.
18th Feb 2024, 1:23 pm | #26 |
It’s all back and working correctly. The lack of output was my stupid fault. There are a set of links to select the modulation polarity , I had them both selected and so killing the output from the IC. With one one selected it came to life.
Thanks again for the help and advice Malcolm |
