Old 28th Dec 2023, 3:30 pm   #1
Default Roberts RM40 - the dreaded Lockfits!
My RM40 started making a strange low-frequency 'fizzling/burbling' noise through the speaker.
The burble's level didn't change with the volume setting - indeed it continued unabated even when the volume control was at zero so I knew it had to be in the audio output stage rather than in the preamp/tone-controls or the audio part of the AM/FM/AUX signal-source switching.
Looking at the circuit diagram revealed that the first audio amp was a BC149.
A-Ha! A Lockfit! So without further ado it was excised and replaced by a nice new-old-stock SGS branded BC109C.
Tweak the bias pots to get the voltages spot on, reassemble, and the burble has gone.
I love it when a fault is easy to fix.
A proper amplifier dims the lights when you switch it on.
Old 28th Dec 2023, 4:04 pm   #2
paulsherwin
paulsherwin's Avatar
Default Re: Roberts RM40 - the dreaded Lockfits!
Yes, that's a classic bad Lockfit fault. As you say, fortunately it's an easy fix, especially if you've encountered it before.
paulsherwin is offline
Old 28th Dec 2023, 4:20 pm   #3
I've come across it before; these days I treat Lockfits with the same level of visceral dislike as the AF11x type whisker-transistors and that other early-1970s horror the Texas Instruments SN7600x range of audio-output ICs which have a horrible tendency to self-destruct.
Old 3rd Jan 2024, 11:54 pm   #4
Maarten
I'm wondering what the production code on the lockfit transistor is. Did you by any chance make a note of it?
Maarten is offline
Old 4th Jan 2024, 2:25 pm   #5
Alas I didn't bother with recording any details of the failed Lockfit before I threw it in the bin.
Copyright ©2002 - 2024, Paul Stenning.
