2nd Jun 2021, 2:47 pm | #1 |
Valve Testing
Hi
I've got some Mazda PP5/400 Valves and was looking for some advice to how / who i can get them tested by please? Last edited by Cobaltblue; 2nd Jun 2021 at 2:51 pm. Reason: % becomes 5 |
2nd Jun 2021, 3:24 pm | #2 |
Re: Valve Testing
They are easily tested in the sets they belong to. Just a quick check of the anode current they are running at and the grid bias voltage will tell you whether they're OK.
It saves on all the risk of handling/shipping them and is definitive in terms of whether they're OK in their set. These are pretty rare valves, replacements are hard to get and the audiophool fraternity have pushed the prices up to astronomical levels. David
2nd Jun 2021, 5:51 pm | #3 |
Re: Valve Testing
If these valves were a speculative acquisition & not out of a radio or amplifier that you own, then in all honesty you'll need to get them tested on a decent VCM( by a knowledgeable/experienced person), prior to flogging them. (£££'s in your eyes ?).
I'll echo David's post - these are jolly rare Power Triode valves. Avoid at all cost Royal Mail or any other Postal/Courier service, unless you wrap them with several inches of Rocking Horse Manure & plenty of bubble wrap! I tested a number of these types of triodes plus other DE & BE valves(£2K +) from the same era(1920's/30's - 90 years old !), a while ago. BUT - they were hand delivered & collected by a BVWS chum - the owner, who lived about 30 miles away. All I charged him was the cost of an extra pair of underpants. The London area must be awash with valve testing enthusiasts. Regards, David |
2nd Jun 2021, 6:14 pm | #4 |
Re: Valve Testing
I knew some "audio fool" valves where expensive, but 2k, that's taking a whole packet of Hob Nobs. Modern valves that are still being made are much better in all aspects. As David said, just measure in circuit or don't bother if it works.
2nd Jun 2021, 7:25 pm | #5 |
Re: Valve Testing
At those prices few private individuals would test them for you out of fear of liability. Only someone with a commercial repair operation is likely to have liability insurance in place, and they would see it as a business transaction and would expect to see a proportion of the apparent gain in value due to the testing.
The radio restorer has it easy, testing in situ is just fine. David
3rd Jun 2021, 5:05 pm | #6 |
Re: Valve Testing
Hey MM - 'twasn't £2k for one heffing Triode - about 40 odd valves in a well padded big plastic box. As well as PX25 types, some were cruciform, and there were one or two KT's. £2k is what all of them might have realised on eBay, going by their average prices at the time. When I opened up my pal's box, some of the valves were in their original NOS boxes and some just wrapped in plenty of old paper towelling, which, after testing, I put into some of Pamphonica's great "flat-pack" new boxes.
I just mention this so that Valerwee understands how much care needs to be taken with such rare valves. Thankfully I didn't phook any of my pal's valves, but its not something I do, or would do, commercially. I have, very occasionally, Ebay'd one or two of these NOS rare old power triodes, but(as folk who ken me know) they were all flogged along with an A4 Gm graph. Whether folk are audiophools or not, I would recommend that you shouldn't buy such hexpensive valves without a graph. After all, back in the 20's & 30's many such power triodes, and later BT's & Pentodes, all came with a graph printed on the side of the box or folded up inside. (Buying a valve online, with the small print saying - "AVO VCM Tested", sometimes means SFA!). Regards, David |
3rd Jun 2021, 5:11 pm | #7 |
Re: Valve Testing
I have seen many valves for sale with small print, or even large print, saying that the valve has been tested on this, that or the other valve tester. Unfortunately they often omit to say whether the result of the test was good or bad.
Stuart The golden age is always yesterday - Asa Briggs |
3rd Jun 2021, 5:16 pm | #8 | |
Re: Valve Testing
3rd Jun 2021, 7:30 pm | #9 |
Re: Valve Testing
The case of the 'half heater' with PX4 and PX25 valves is a very real one. personally I would much rather buy new replica valves. They are very good quality.
I certainly would not spend hundreds of pounds on second hand junk and even if they tested good they would probably have a limited life. Just my thoughts. John. |
