#261 |
It may come down to which one is more available, as these are both going to be fairly uncommon devices now.
Did you do the checks in #255? |
#262 | ||
All measurements taken below with my scope.
UD3/14 - 5.15v UD3/7 - 0v UD3/1 - moves up to 1.13v and stays there UD3/13 - moves up to 1.13v and stays there UD3/5 - 4.58v but no frequency UD3/9 - 4.58v but no frequency UD3/2 - 4.58v but no frequency All previous frequency measurements taken with my scope. Colin. Quote:
#263 |
#264 |
Would you like screenshots of my freqnecy tests to ensure I haven't got it wrong (again)?
Colin. |
#265 | |
No, wait, they should both be at a decent logic-1 level. The chip is most likely being held in an OFF state. I don't have time to look, does that version of the PCB have 2 x 5V regulators and if so are you getting +5V out of BOTH of them? |
#266 |
So there's two different types of voltage regulator (See attached photos).
I've not tested the ones that are VR2, VR3 and VR4 before - is it simply a matter of using one of the legs that have nuts on for testing? Colin. |
#267 |
The two 7805 regulators (barely identifiable through the rust) are the two closest to the transformer, the one furthest away from the transformer on that heatsink is the +12V regulator and the smaller black regulator in the corner is the minus voltage regulator.
Measure on the 'blank' (non-banded) ends of diodes CR6 and CR7 where you should have +5V on each of those points. If either of them are NOT at +5V move to the other end of the relevant diode and measure the voltage at that end. |
#268 |
When you're ready for it, here's an updated ZIP file, with both the quick and full tests:
testrom_06.zip Contents:
#269 | |
Both read +5.12v.
Colin. Quote:
#270 |
Find R28 (1K) and R2 (1K) and measure the voltage on each end of both of those resistors (use a meter, to be on the safe side).
R28 is the INIT line pull up resistor, R2 is the PULLUP_1 pull up resistor. The fact that both of those (independently pulled up) rails are reading low is what made me suspect you had lost one of the +5V rails. So this is to see if they do, or do not, have +5V on their 'hot' end. |
#271 |
R2 has +5.1v at one end and +0.96v at the other.
R28 has +5.07v at one end and +0.96v at the other. Colin. |
#272 |
So no problem with the +5V supply to the tops of those pull resistors.
I am unfortunately quite busy tonight and then away for the weekend - those two voltages which are sub- 1V should be a lot higher, you need to find out why they are so low. When it's been on for a while have a look with your thermal camera to see if any of the ICs look unusually warm. Maybe for reassurance, swap the 4032 PCB back in and measure the voltages on those points, including UD3 pins 1 and 13, to see what they should be on a working system. I am sure they should both be up at logic-1 level and as they are not, a lot of the ICs including UD3 will currently be held in an inactive state. |
#273 |
I've just noticed something. Both times when you have measured the voltages on UD3 pins 1 / 13 and R2 and R28 'cold' ends - which are the same circuit nodes measured at a different point, the voltages were identical to within 100th of a volt. For both of those nodes to have exactly the same voltages on them is quite unlikely.. unless they are shorted together.
To rule that out, with power off, measure the resistance between UD3 pin 1 and UD3 pin 13. |
#274 |
Working 4032 readings:
R2 - +4.936v one end, +4.901v the other end R28 - +4.927v one end, +4.896v the other end Resistance between 4016 UD3/1 and UD3/13 - 141 ohms. Colin. |
#275 |
That resistance seems rather low to me, although not as low as I expected. The same resistance, measured, power off, between UD13 pins 1 and 13 on the 4032 PCB is...??
(When making the measurement have the red and black leads the same way around, so red to pin 13, black to pin 1 for both measurements). It is looking as though possibly one of the ICs which has a connection to both the Pullup_1 line and the INIT line has failed, making that low resistance connection between them. UD3 is one of the ICs which is connected to both lines, so it could yet be the culprit. INIT goes absolutely everywhere, PULLUP_1 not so much, so if you follow the PULLUP_1 line and note every IC that that goes to, then see how many of those are also connected to INIT, that may narrow it down. |
#276 | |
Sorry, this may not have been clear.
#277 |
And if in doubt, measure both ways anyway; but be sure to say which is which, e.g. "1.62k? with red on IC1 pin 1 and black on IC3 pin 4, crept up from 1.1M? to OL with black on IC1 pin 1 and red on IC3 pin 4".
#278 | ||
OK - red probe to pin 13, black probe to pin 1 of UD3.
4016 - 131 ohms 4032 - 2k ohms I measured with the probes the other way round and got the same results on both motherboards. Colin. Quote:
#279 |
Here's the ICs that are common to both INIT and PULLUP1 as far as I can see (happy to be corrected):
UE7 UE6 UD3 UB1 UB2 UC1 UE1 UE7, UE6 and UD3 are all 74177 devices according to the BOM. All are connected to Pin 1 for PULLUP1 and pin 13 for INIT UB1 UB2 are 74LS74 according to the BOM and UC1 and UE1 are 74S74 according to the BOM. All of UB1, UB2, UC1 and UE1 are connected to multiple pins (up to 4) for INIT/PULLUP1 - I have the notes if needed. Colin. |
#280 |
That's fair enough, so you can see from those differences that there is something definitely up there - the 131 ohms is almost certainly being measured through a failed chip which is connected to both of those normally pulled-up rails.
As said earlier my suggestion to try to narrow down the source of this unwanted low resistance between those lines is to follow the PULLUP_1 line wherever it goes to on the circuit, noting the IC numbers of any ICs it visits, and then look to see how many of those ICs are also connected to the INIT line. This may narrow down the range of suspects. UD3 is one that we already know about, but can you find any others? Edit: I see you are ahead of me. Quite a long list! I suppose it's fair to assume none of them are currently in sockets? |
