Old 6th Dec 2017, 8:15 pm   #1
skamanuk
Default Garrard 4HF Pitch control
Hi I have a Garrard 4HF deck but unfortunately the pitch control (I think that's what its called) isn't working the 4 speeds work fine but I can't fine adjust the speed. The small knob turns but nothing happens. Any help please. Gary
skamanuk is offline
Old 6th Dec 2017, 8:44 pm   #2
vidjoman
Default Re: Garrard 4HF Pitch control
I think they were quite stiff so maybe the knob is loose.
vidjoman is online now
Old 6th Dec 2017, 11:20 pm   #3
skamanuk
All seems tight.. The knob turns and theirs weird kind of spring noise at the extreme limit of the turn in both directions??
skamanuk is offline
Old 7th Dec 2017, 10:18 am   #4
vidjoman
It's a wirewound control so it would seem the wire has probably broken. Need to take it apart to find out. Probably a standard value pot can be fitted in it's place.
Old 7th Dec 2017, 11:54 am   #5
Edward Huggins
"The Classic Turntable Company" may have spares.
Edward.
Edward Huggins is offline
Old 7th Dec 2017, 11:40 pm   #6
skamanuk
If I can fit a standard Valve pot it would make life a lot easier..
skamanuk is offline
Old 7th Dec 2017, 11:56 pm   #7
Michael Maurice
Michael Maurice's Avatar
I dont think a standard pot will work, if I remember, the pot is around 20W, maybe more.
Forum Moderator
Michael Maurice is offline
Old 8th Dec 2017, 2:01 am   #8
teetoon
Hello. This was discussed on Vinyl Engine and a wiring diagram posted that might be of help. The high voltage diagram is the one for UK mains.
As Michael says, it will need to be a high wattage control but not sure of the actual rating.
Hope this is of some help.
Edit: further reading shows a 25 watt OHMITE RHS10KE being a good fit if you can find one.
David.
Name:	4HF wiring diagram.jpg
teetoon is offline
Old 8th Dec 2017, 2:37 am   #9
teetoon
The pots are available on ebay but not cheap. About £30 inc post.
See images.
David.
Name:	Ohmite control.jpg
ID:	153599   Click image for larger version
Name:	Ohmite RHS10KE.jpg
teetoon is offline
Old 8th Dec 2017, 6:05 am   #10
TonyDuell
As a sort-of aside, I was amazed to find (while looking for something else) that RS sell 'rheostats', including the one in this thread :
https://uk.rs-online.com/web/p/rheostats/8915379/
Some of the higher power ones are _very_ expensive, and I wonder what they are used for these days.
TonyDuell is online now
Old 8th Dec 2017, 8:24 am   #11
GP49000
The control for a Garrard RC98 would probably work. But this isn't much help because if anything, the RC98 is uncommon; fewer were made than the 4HF.
GP49000 is offline
Old 9th Dec 2017, 12:25 am   #12
skamanuk
Thank you for the help... Found and ordered
skamanuk is offline
Old 21st Dec 2017, 2:09 am   #13
teetoon
Hi Skaman. Any news on this? I am interested to hear if you got it sorted as I have a couple 4HF's and the pitch control is a weak spot on these. The actual fitted controls are the sort you would find on the back of TV's.
I had my first 4HF back around 1972 and the control smoked and got replaced by a couple of wirewound resistors (by my Dad). We later discovered that the motor had shorting turns.
On my later 4HF's there is a slight burning smell if you adjust the control but it clears and the motors only get warm so I assume Garrard only meant the controls to be adjusted sparingly.
David.
teetoon is offline
