Old 30th Nov 2017, 4:56 am   #1
FrankB
Default Surface mount parts- RIP. (Rest in Place)
While replacing some SMT parts in TV sets, I had a ****** of a time getting them to stay in place while I soldered them. After a mutual grumbling session with my friends, one of the girls suggested eye lash glue.
Use the Latex base stuff. (If it smells like ammonia, don't use it). A pin point size drop of the clear stuff, properly dried, held the parts just fine. Non- conductive too, if you don't use the black stuff.
It took some experimenting, but the gal at the local makeup counter was delighted to sell me 5-6 different types to putter with. One tube will likely last for hundreds & hundreds of parts.
Oh, yeah, be sure to put the cap back on tightly too. It turns into a rubbery blob if you don't.
The black type seems somewhat conductive, as I think an ingredient is carbon black or charcoal for the coloring. At least the stuff I tried was conductive on the meter.
I ran 1" strips of it on glass, and measured conductivity with my meter. One result of this was my SO had a many years supply of the types that were not suitable. Some of the adhesive types had chemicals in it that I was not sure would be safe for the chips and components.
FrankB is offline
Old 30th Nov 2017, 5:16 am   #2
Boater Sam
Boater Sam's Avatar
Default Re: Surface mount parts- RIP. (Rest in Place)
Now then, you may have hit a bull's eye there with a bit of lateral thought.
Conductive silver paint is hellish expensive but black lash glue isn't.
Food for thought?
Boater Sam.
BVWS Member
Boater Sam is offline
Old 30th Nov 2017, 7:47 am   #3
Paint-on resistor!
DIY answer to screened and fired thick film hybrids?
Radio Wrangler is offline
Old 30th Nov 2017, 11:28 am   #4
Colin G8TMV
Paint-on resistor!
A company I do some work for makes equipment for testing printing inks. They have recently been involved with a different company doing research into printable electronics, including *active* components.
Colin G8TMV is offline
Old 30th Nov 2017, 11:46 am   #5
paulsherwin
paulsherwin's Avatar
I wonder if a dab of nail varnish would also work as an adhesive?
paulsherwin is online now
Old 30th Nov 2017, 12:24 pm   #6
AC/HL
AC/HL's Avatar
What goes around!
I seem to remember that early grid leak resistors were sometimes made by soaking cardboard with Indian Ink.
Bill, BVWS member
AC/HL is offline
Old 30th Nov 2017, 1:55 pm   #7
Bazz4CQJ
Bazz4CQJ's Avatar
As a kid I used to collect my sister's discarded nail varnishes and used them for all kinds of odd tasks, e.g. fixing coils in place on formers. Ah... the smell of nail varnish .
B
We know there are known unknowns. But there are unknown unknowns ones we don't know we don't know.
Bazz4CQJ is offline
Old 30th Nov 2017, 2:21 pm   #8
MrBungle
MrBungle's Avatar
They're pretty easy to get to stay put. My trick, which requires no glue is:
1. Tin the pad slightly.
2. Get some tweezers, stick the part on top of the pad and just heat it to tack solder it.
3. Solder diagonally the other end.
4. Solder the original end again.
5. Solder the rest of the pins.
6. Clean up with wick, then IPA.
I've done this about 500 times now and no glue required! Works down to 0402's, TSSOP, SOIC, SOTs, the lot.
Using these tweezers, which are worth the cost: https://uk.rs-online.com/web/p/tweezers/8348161/
MrBungle is offline
Old 30th Nov 2017, 8:04 pm   #9
McMurdo
McMurdo's Avatar
Yes, a good pair of non-magnetic tweezers, and then flux.
I'm not keen on glueing these things down. Although essential for high speed pick & place machines, some smt glue (ie the stuff actually meant for the job) has been found to turn conductive after some years.
One product in particular I can think off had a raft of mods to overcome random pcb leaks caused by dots of glue under capacitors. I'd have never found such faults without access to the manufacturer's bulletin.
Kevin
McMurdo is offline
Old 1st Dec 2017, 12:42 am   #10
If anyone can show me the difference between RS anti tamper seal and red nail varnish, I'd be interested......
Herald1360 is offline
Old 1st Dec 2017, 7:56 am   #11
MrBungle
MrBungle's Avatar
Street cred
MrBungle is offline
Old 1st Dec 2017, 8:06 pm   #12
jay_oldstuff
jay_oldstuff's Avatar
When i was in the PC repair business I used nail varnish as anti tamper seal, so much cheeper (free if your GF doesnt notice it missing )
The light at the end of the tunnel is probably the headlight of an oncoming train
jay_oldstuff is offline
Old 1st Dec 2017, 10:51 pm   #13
kalee20
Now there's a thing - if I was a girl, I'd want to paint my nails with the RS varnish. May not get the street cred- but definitely lab cred!
I usually tack SM parts down on one pin or pad, like MrBungle. Or I use a cocktail stick to hold it down, and flood the whole thing with solder, afterwards draining it away by holding the board upside-down and visiting the iron underneath. I definitely don't like any glue if I can help it!
kalee20 is offline
Old 2nd Dec 2017, 8:39 pm   #14
trickie_dickie
trickie_dickie's Avatar
As someone who did all the company SMD repairs and prototypes, I can say that I have NEVER glued any components to the board. Totally unnecessary.
Richard
trickie_dickie is offline
Old 6th Dec 2017, 8:15 pm   #15
SiriusHardware
I have to agree - I solder SMD devices every day including some very fine pitch quad sided ICs and I just manouvre those into place while looking straight down on top of them through a magnifier and solder two opposite corner pins, briefly melting and moving one or the other again if necessary until the IC is dead in position. Then I solder the rest.
For smaller 2-pin, three pin devices and small ICs of up to about 16 pins I clear all the pads of solder and then put a shallow blob of solder on just one pad which I melt while manouvreing the part into place. That single spot of solder then holds the device in place while I solder the rest.
-But. The OP's discovery of the conductive version of this goo makes it sound like a promising repair agent for those rubber membrane keypads whose conductive rubber button 'carbon pills' no longer conduct.
SiriusHardware is online now
Old 7th Dec 2017, 3:11 pm   #16
Welsh Anorak
Welsh Anorak's Avatar
I've always found that introducing glue under an SMD IC is a mistake as it causes the chip to be too high. Like Sirius above, I find if the pads are completely clean the IC will sit square on them. A small blob on one corner (assuming a quad) then a little manipulation with the tweezers and a blob on the opposite corner and then the solder will take. If the pins are even fractionally above the pads then you can't do a good job. And what if you need to remove the new IC?
Glyn
Welsh Anorak is offline
Old 4th Jan 2018, 2:42 am   #17
FrankB
I never had any removal problem with the eye lash glue, if I had to change out the part.
Remember I said a "pinpoint" amount.
I worked on mass consumer electronics and often turning the boards upside down, etc. was not an option. I had to work with the boards at odd angles, and getting a SMT part to stay in place long enuf to tack it with solder was nigh onto impossible.
The" conductive glue" thing was rampant in consumer electronics here in the States. I remember having to remove it from many Pioneer, PCE, and other brand stereo receivers and TV sets, and even car radios.
FrankB is offline
Old 4th Jan 2018, 6:30 am   #18
Appropriate to the title of the thread, when badly located SMT parts stand on end due to surface tension on one end exceeding that on the other when the solder melts, it is called 'Tombstoning'
For use as prodders when soldering, tagstrips , T-H PCB, or SMT, cocktail sticks are rather useful. HP had them set up in stores, complete with part number. Guess who set up a part number for "Washer, Non-Ferrous, Mint Flavor" ? (American simplified spelling and engineering drawing included)
Old 4th Jan 2018, 7:33 am   #19
mole42uk
mole42uk's Avatar
Did you also set up a part number for “Olives, stoned, green”?
Richard
Index:
mole42uk is offline
Old 5th Jan 2018, 9:11 pm   #20
Someone in need of a lifesaver?
There must be a way to get chukka in there somewhere. Maybe it's how long the washer lasts?
