Old 4th Nov 2017, 6:13 pm   #1
robinshack
Default Kenwood Chef food mixer safety observation
As title. Our mixer is a little over 40 years old. I think it is either an A701, or A701A. It is white and dark blue. Used possibly once a month these days. About 10 years ago, the capacitor burnt out, so I replaced just that part, all was fine. Switching on last week, the whole thing made a lot of noise and the speed knob was seen to be moving around violently. Machine was switched off immediately.
It was soon apparent the motor had come adrift from it's rubber mountings. Available on ebay, over 8 for the four. I was convinced I had something similar....somewhere. I even placed a "wanted" post!
Today, I found what it was I was thinking of. A set of strong, new, rubber mountings as used for domestic refrigeration sealed unit compressors. All I needed to do was reduce one side thickness slightly by cutting some rubber away with small sidecutters. Other than this, the dimensions were just right. I fitted them and ran the motor up and all was fine. Sorted!
However, the result of this new thread concerns electrical safety. The machine frame is all metal, but mains flex is 2 core, without earth. The electrical insulation safety integrity is provided by the rubber bushes insulating the motor electrically from the whole frame. My original bushes had perished and disintegrated, allowing the motor frame to move around within the non-existant insulation bush and most likely touch the metal fixing screw that was connected to external metalwork. Not a nice thought.
What I have done is to provide an earth wire from a 4BA solder tag, attached under a motor stator screw. This will connect with tyhe earth wire of a new 3 core mains lead that I will fit. Unfortunately the mains terminal board on the mixer is only 2 screws, L & N. So, I will connect the new 2 earth wires together using a butt crimp terminal.
This will give me peace of mind, that the metal frame of the motor is earthed at all times.
No doubt, such a modification to enhance safety is a wrong act on my part, as it is a modification from original manufacture. However, at least I will feel safer!
Rob
I think a little difficulty in life inspires the special day in our brain.(Yuuji Shimomura)
robinshack is offline   Reply With Quote
Old 4th Nov 2017, 7:12 pm   #2
rambo1152
Default Re: Kenwood Chef food mixer safety observation
In technical terms what you have done is convert from the original "Class 0" to "Class 1"
By coincidence, I contributed to a discussion yesterday in a different place about the same thing with antique photographic equipment, and the consensus was it's a very Good Idea (tm).
When there is a conflict between electrical safety, particularly in the kitchen, and "originality" I know which one I regard as more important.
Graham.
G3ZVT
rambo1152 is online now   Reply With Quote
Old 5th Nov 2017, 9:16 pm   #3
robinshack
OK Graham, I agree entirely.
Test run this morning, all fine. I got the hot, slight burning smell as sometimes witnessed by other repairers, especially after changing the wirewound resistor.
I didn't investigate further as I assumed it was grease and some dirt coating said resistor. After a few minutes running, the smell disappeared.
During my earthing process, I also linked an earth wire from the aforementioned motor stator chassis to the main frame as well. Under the screws of the hinge bracket. Just in case.....
Rob
Old 5th Nov 2017, 11:43 pm   #4
Refugee
Refugee's Avatar
I will have to keep an eye on ours.
The old one has been fitted with an earthed power cable for screening due to it having a rev counter fitted.
Refugee is offline   Reply With Quote
Old 6th Dec 2017, 12:46 pm   #5
Fidelity Fan
James May put one of these back together in an episode of The Reassembler made a year ago. It was very informative, but unfortunately I cannot find a link to the complete episode.
Fidelity Fan is offline   Reply With Quote
Old 12th Dec 2017, 6:52 pm   #6
McMurdo
McMurdo's Avatar
I'm sure my mother's had a double insulated sign on it, certainly they were BEAB approved
Kevin
McMurdo is offline   Reply With Quote
