20th Nov 2017, 6:46 pm | #1 |
Chimney antenna-mount: twist or clamp?
I've got the roofers/chimney-stack-rebuilders in at the moment, and intend to use the access their scaffolding provides to put up a Hy-Gain 12AVQ HF antenna.
A couple of 18-inch galvanised 'Mitre brackets' will be used on the chimney itself. The 'traditional' way to attach these is with a galvanised wire round the chimney - and usually the ends of the wire are simply twisted back on themselves to provide a 'loop' for the J-bolts that are then tightened. I don't like this twisted approach: my idea is to use stainless-steel yacht-rigging wire and similarly-sourced "U-bolt clamps": https://www.s3i.co.uk/stainless-steel-rope-grip.php which should last well enough to see me into the time when HF DXCC is really not the sort of thing I'm interested in. Ideas? Suggestions? Should I use 'thimbles' where the wire is attached to the J-bolts? |
20th Nov 2017, 7:02 pm | #2 |
Re: Chimney antenna-mount: twist or clamp?
When I was a lad we used to fold the lashing cable round the thimble. Then we would untwist about a foot of said cable and wrap each strand in turn around the two 'passes' of lashing cable. When that strand ended, we'd wrap the second strand until that also ended, then the third, and so on. If you get my drift. Hope this helps. Cheers, Pete.
20th Nov 2017, 7:10 pm | #3 |
Yes that wrapping-style is what I'm familiar with - it's the same as used in the classic double-ended "Western Union" splice on overhead telegraph lines.
Problem is, stainless-steel strainer wire is really a lot more-springy than the galvanised-iron lashing-wire of old. Getting the individual strands of stainless to play nicely and not spring undone when I wind the J-bolts up to a decent torque could be a problem; hence my interest in using U-bolt clamps. |
20th Nov 2017, 8:04 pm | #4 |
No personal experience, but the accompanying extract from a text book on ropework for yachts (Modern Rope Seamanship, Colin Jarman and Bill Beavis, 2nd Edn, 1983) explains how to make reliable splices in wire ropes. It confirms the need for thimbles (as large as possible) and that the clamps (bulldogs) need to be correctly oriented to avoid damaging the wire. The alternative would be to use a swageless terminal.
20th Nov 2017, 8:07 pm | #5 |
Note that some u bolt clamps have undersized threads and won’t reliably clamp the wire.
20th Nov 2017, 8:33 pm | #6 | |
20th Nov 2017, 8:35 pm | #7 | |
"Cheap" is OK, but not when it involves paying to get scaffolders out to let me reach the failed parts. |
20th Nov 2017, 8:41 pm | #8 |
Stainless steel duplex grips for a loop.
Lawrence. |
20th Nov 2017, 9:28 pm | #9 |
When using stainless steel marine fittings, how do people avoid the pick-up or galling problem on tightened threads; application of some type of a preferred grease, or PTFE tape... ? I've seen some expensive bits of kit completely blethered when people were mean with the tape on stainless pipe fittings!
B
21st Nov 2017, 5:03 pm | #10 |
Good choice to use stainless if you burn solid fuel. Our Rayburn range burns coke and anything mounted on the chimney is eventually compromised due to the mildly corrosive fumes coming from the stack. A lot of standard rigging items seem to be made from fairly soft iron too with a rather thin galvanised coating so they don't last very long when exposed to smoke. I just tend to coat mine with black underseal clag and inspect them fairly often. I'm a bit of a monkey for trying out new antennas so that isn't a problem, and it keeps the neighbours entertained when I'm clambering about on the roof. I find that a bit of plastic tubing pushed over exposed threads on bolts helps a lot when you need to remove the nuts later on.
Alan. |
21st Nov 2017, 6:36 pm | #11 |
That sounds like the usual declining standards to meet expectations of ever lower prices. Admittedly it's quite a few years since my duties as a general workshop engineer included aerial rigging, but the steelwork was always heavy duty and well galvanised. I used the same method as Pete in post 2.
