Old 13th Nov 2017, 8:10 pm   #1
Hmn0105
Default Fidelity HF45 - record slip during play
Hi everyone, my daughter has I believe a Fidelity HF45 which has recently started playing with some slippage.
I am going to check the mat under the LP on the deck but if it’s not that what else can I easily check. It looks like a BSR deck. I am fairly practical but have not taken one of these apart before.
Anyone’s advice would be very welcome.
Thank you so much.
ID:	152210   Click image for larger version
ID:	152211   Click image for larger version
Hmn0105 is offline
Old 14th Nov 2017, 10:20 am   #2
'LIVEWIRE?'
'LIVEWIRE?''s Avatar
Default Re: Fidelity HF45 - record slip during play
That is a BSR Deck. One of the later Cxxx series by the look of it. I would check that the stylus is correctly seated and not worn or chipped. The front part of the stylus, where the actual 'needle' is, should be located between two rubber 'ears' at the front of the cartridge. The mat is unlikely to be the cause of the problem.
'LIVEWIRE?' is offline
Old 14th Nov 2017, 11:33 am   #3
Edward Huggins
It may also be slippage on the Drive (Idler) Wheel to the inside rim of the turntable platter. Remove the circlip from the base of the spindle, ease off the turntable and clean the idler, stepped motor spindle and inner turnable rim wih IPA/Meths.
Edward.
Edward Huggins is offline
Old 14th Nov 2017, 12:27 pm   #4
'LIVEWIRE?'
Edward, why didn't I think of that? I've serviced enough record players in my time!
Old 14th Nov 2017, 8:03 pm   #5
Hmn0105
Many thanks. I changed the stylus and still have some slippage. I’ll check under the turntable later this week when home.
Hmn0105 is offline
Old 14th Nov 2017, 9:40 pm   #6
Audio1950
Good advice, but isn't the turntable plastic? If it is, won't IPA melt it?
Audio1950 is offline
Old 15th Nov 2017, 10:24 am   #7
GeoffK
No it is acetone that chemically melts certain plastics.
Geoff
GeoffK is offline
Old 15th Nov 2017, 10:52 am   #8
Audio1950
Thanks Geoff, I never was any good at chemistry!
Old 19th Nov 2017, 6:26 pm   #9
Hmn0105
Many thanks. To my ears it sounds fixed. I’ll confirm after my daughter has played a few LP's
Hmn0105 is offline
Old 19th Nov 2017, 11:07 pm   #10
AC/HL
AC/HL's Avatar
Back when these players were current IT equipment, that was about the sum total of their maintenance, perhaps with the odd stylus replacement.
AC/HL is offline
Old 21st Nov 2017, 9:30 pm   #11
crackle
Be aware that if you are playing stacked records, then if any are slightly warped then they can slip against each other.
Mike
crackle is offline
